Old 08-14-2008, 05:17 PM   #1
project 67 sub
project 67 sub's Avatar
Unhappy th400 trans problems........need help
ok. so i replaced the selector shaft seal, and it still leaks like a siv. so can i pack some silicon or something around the selector shaft so i dont have to pull my trans. all back apart to try and fix it again and possibly still have the same problem. any help is greatly appreciated.
project 67 sub is offline   Reply With Quote
Old 08-14-2008, 05:21 PM   #2
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
Re: th400 trans problems........need help
Packing RTV around it will only make your fingers messy. If it was the correct seal, then there must be a groove around the shaft. I'd pull it back out to see what the deal is, you want to fix it right don't ya? nows the time!
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 08-14-2008, 09:36 PM   #3
kelsfine69
18 Till I Die
kelsfine69's Avatar
You might have nicked the seal putting it in. Check for a groove where the seal rides. A new seal should fix her up.. I cant remeber if you can pull the shaft with just dropping the pan.
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 08-15-2008, 12:47 AM   #4
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
I use a special tool that draws the old seal out without removing the shaft. You will probably find a gouge in the case bore from prying it out, a nick or wear in the shaft, or if you didn't de- bugger the end of the shaft when sliding it thru the seal, it might have damaged the seal lip. You also want to rotate it as you start it into the seal, so it doesn't try to roll the lip.
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD
'72 K20 500 Cad/TH400/NP205 SOLD
'92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver
'72 Monte Carlo... sweet low mile toy
'11 Dodge Challenger IE 392 6spd... midlife car
jeffspower is offline   Reply With Quote
