Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 08-14-2008, 05:54 PM   #1
uncle
Lighten the Frontend?
I have a local guy wanting to lighten his front suspension on his 68. It is a race only truck and already has disc. He' asked me about tubular a-arms,ect.,but I told him I had no experience with such. Any suggestions?
uncle is offline   Reply With Quote
Old 08-14-2008, 10:10 PM   #2
Rodms
Rodms's Avatar
Re: Lighten the Frontend?
Let me know when you get it figured out cause i need to drop a couple of hundreds of pounds
Built chevy tuff!
Rodms is offline   Reply With Quote
Old 08-14-2008, 10:22 PM   #3
ripdog28
ripdog28's Avatar
Tubular A-arms will lose about 40-50lbs Check with Performance Online or Classic Perform. If you do not mind spending about $800-1000 which is the easiest route to take off the most weight go with a glass front end.
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 08-15-2008, 09:41 AM   #4
Marv D
Registered Truck Offender
Marv D's Avatar
The weight thing is as much a budget thing as anything else. For around $4k to $5k you can slap a light weight glass front end on something like this
easy way to loose about 1000 pounds off the nose
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 08-15-2008, 06:52 PM   #5
67dragtruck
67dragtruck's Avatar
The fatmans setups will save somewhere around 200
Tom
No more dragtruck for me. I'm building a new ride though. It's a '71 fleetside, 400 sbc, 700R4. Working on it now, finally. Soon to have Edelbrock Pro Flo EFI, Vintage Air, 1 piece windows, buddy buckets, etc.
My new build thread:
http://67-72chevytrucks.com/vboard/s...17#post2861817
Best pass with the old dragtruck:
5.32 @ 131.6 mph 1/8 mile w/ a 1.25 60' Fogger/Plate 2003
Best pass with the street 406 hydraulic roller motor w/ mild plate tuneup
5.93 @ 114 mph 1/8 mile w/ a 1.29 60' 2003 or 2004
67dragtruck is offline   Reply With Quote
Old 08-15-2008, 11:51 PM   #6
PA-IndianRider
PA-IndianRider's Avatar
Ahhhhhhh........ I know what I will be "dreaming" about tonight
John aka "Milner"
PA-IndianRider - Pittsburgh, PA
70 Chevy C10 Stepside
"Gasser/Altered Drag Race Hot Rod"
Where were You in '62 ?
PA-IndianRider is offline   Reply With Quote
