parking brake bracket on frame
Does anyone know if the parking brake bracket where the front cable hooks up on the frame by the tranny is the same on 2WD and 4WD trucks? The bracket shown is on a 72 1/2 ton 4x4 and I need one. I have access to a parted out 72 2WD truck but I don't know if they are the same. If anyone has one of these on an old frame they could part with, please PM me. Thanks.
1967 Chevrolet 1/2 ton 4x4 1972 GMC 1/2 ton 4x4 2005 1500 4x4 Suburban 2004 GMC Envoy 4x4 (wife's) |
Re: parking brake bracket on frame
On 2wd frames there is a hole in the frame that the parking brake cable runs through.
2nd that, there is no bracket on 2wd frames, at least not on mine.
1970 2wd short/fleet 350/350 Project "iced green dream" http://67-72chevytrucks.com/vboard/s...d.php?t=272702 2006 Toyota Tacoma double cab 4x4 |
I'm still interested in finding this part if anyone has one. Would be shipped to 58501. Thanks.
![]() Join Date: Sep 2007
I just pulled a trans crossmember out of a 68 chevy 3/4 ton big block auto trans column shift and I didnt see any bracket like that under there, what this one had is 2 oblonged mounts that were bolted to the center rear part of the crossmember that the e brake cable ran thru. Kind of like an equalizer
1967custom Last edited by michael bustamante; 04-01-2009 at 02:23 PM. |
Restoration Virgin!
Hey lugnut,
I post this alot.....this is the ebrake setup for 67/68...not sure it helps, but other than the ebrake handle in the cab, I think the routing is the same??
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present Last edited by gcburdic; 04-01-2009 at 03:43 PM. |
From the replies i received, it doesn't sound like the 2WD frame has this bracket on it. Do any of you guys have a 4x4 frame with this bracket? I need to get one of these brackets. Thanks.
