08-15-2008, 01:50 PM | #1 |
Engine Stands
I have a question?
How much does a SBC 400 weight and what kind of engine stand do I need to rebuild im new at this so I have some dumb questions i know but im learning slowley but surley?
Everything is Bigger in Texas! |
08-15-2008, 02:03 PM | #2 |
Re: Engine Stands
Not sure what the weight difference is between the 400 and the 350 but i just did my 350 and i bought a stand rated for 1500 pounds and it did very well it was realitivaley cheap too hope that helps!!
08-15-2008, 02:12 PM | #3 |
Old Skool Club
Re: Engine Stands
A small block, made of cast iron, has traditionally been said to weigh approximately 700 lbs. Last time I picked up a bare block, it was hard to say (without already knowing) whether it was a 265 or a 327 (which it was). As a rule, since I'm older and smarter, I don't go around picking up (physically) any more engine blocks made of iron. Kinda hard on the sacroilliac.
I bought an A/C Delco engine stand from O'Reilly's for $90. It's a nice stand. Wheels made of steel. Just grease the axles before you assemble them so they won't squeal too soon. It has a rotator feature, for assembly purposes. Be sure to buy some grade 8 bolts that will let you attach the engine to the stand....they're not included. Welcome from the Heart of Arkansas. Last time I was in the Midland-Odessa area I was almost 24 years old. I'm older than that, now.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. Last edited by ChevLoRay; 08-15-2008 at 02:14 PM. |
08-15-2008, 02:28 PM | #4 |
Re: Engine Stands
thx for the help guys
08-15-2008, 04:52 PM | #5 |
Doing it my damn self.....
Re: Engine Stands
I have both a small block stand and a big block stand. I always use the BB stand due to it's ease to roll around. Heavier casters and just all around user-friendly. The price difference in the two at the time was $10. So, I sparnag for the larger one. As the saying goes in tools, go as big as you can afford. Mac or Snap-on if you can, Craftsman Professional at a minimum.
08-16-2008, 07:58 AM | #6 |
Re: Engine Stands
I heard somewhere a 400 CI SBC weighs 560# w/steel headers, iron intake, 4Bbl carb, starter, alternator, but w/o flywheel.
Personally I like to use the BBC stands. They are not that much more expensive, and go on sale at Harbor Freight pretty often. For the 292 L6 [457#] the big block stand is better since it's a top heavy, extra long engine and it needs all the stability you can get. Also I may want to build up a BBC in the near future.
08-16-2008, 08:17 AM | #7 |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Re: Engine Stands
I transferred a sbc400,balancing on a floor jack,to the back of my minivan when I did my eng. swap.
I had to lift it up about 3" to the rear bumper and over a lip. Took everything I had to keep it off my toes. My guess...400lb range. Had everything but the carb on it.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE Last edited by BobbyK; 08-16-2008 at 08:17 AM. |
08-16-2008, 08:44 AM | #8 |
Re: Engine Stands
The one I have is a compact for 1500 pounds and no issues at all....
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
08-16-2008, 01:09 PM | #9 |
Old Skool Club
Re: Engine Stands
I like the wider front stance, but mine has a wider rear stance. At least (for me) I feel good that it has 4 wheels, not three.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
08-16-2008, 06:23 PM | #10 |
Re: Engine Stands
The 4 caster stands are always better to move around without fear of tipping over (jezz that'd blow).
Cable -K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt -Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608 |
