Old 08-15-2008, 04:58 PM   #1
kcjones
I wish I was a cowboy
kcjones's Avatar
Looking for opinions - drop/tires/wheels
I have a 67 C20 that I want to drop (pictures below), convert to 5 lug, and add power disc front brakes. I'm looking for some opinions here:
I'm thinking 3.5"/5" drop, using rear 295/50/16 on 16x10x5bs, and 255/50/16 on 16x8x4bs on front.
-Will my rear tires stick out beyond the bedside fender lip?
-Will my front tires be "too short" (I don't want anymore than about 1.5" between tire and fender lip).
-In measuring my axle [Eaton HO52] to frame clearance on stock springs, it looks like I only have about 5.5" the HO52 is being replaced by 73-87 12bolt 3.42/Posi- I hope this is spring lag, but is it possible that 3/4 tons are different frame-wise, and I'll need to c-notch to go 5" lower?
-While I have everything out, should I go to a 1 piece driveshaft?
-Can I use a 2" drop spring (to get 4.5" drop in front) without negatively affecting caster too much?
I know it's a lot of questions (sorry), but I also know the collective knowledge on this site is exceptional.
PICS:
-Kris
Met list: Cyclone,Wilson,TranzAm,extd56,hotrodhomi,mnky30,Rokcrln,Brad,JerryJones(well, his truck anyway).
kcjones is offline   Reply With Quote
Old 08-16-2008, 09:58 AM   #2
68Stepbed
68Stepbed's Avatar
Re: Looking for opinions - drop/tires/wheels
That's a nice looking 3/4 ton. I don't think I could answer too many of your questions. I will tell you though that giving ECE a call may answer some of your questions. These guys know their stuff. They specialize in 63-72 suspension, so they should be able to help you out.
Also, are you wanting to go 16" wheels for a particular reason? There are many more choices of wheel and tire combinations if you were to go 17". I personally think the wheel/tire combo you have picked out will look a bit strange, especially on a 3/4 ton pickup. Do you plan to leave it 3/4 ton or are you changing to 1/2 ton suspension components?
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 08-18-2008, 04:06 PM   #3
chevguy7
chevguy7's Avatar
Nice looking truck! Definately give ECE a call. They are a great bunch of guys there with a lot of knowledge. That is who I went with my my 3.5/5" drop for my truck. I did not have to do a C notch on my 1/2 ton. 295 is a wide tire but you might be able to tuck that with the right backspacing, I am going to run a 275 in the rear.
1970 C10 - ECE 3.5/5 drop, dual exhaust with turbo mufflers, front discs
http://67-72chevytrucks.com/vboard/s...d.php?t=272458
2000 Buick Regal GS - Supercharged 3.8 V6 240hp, 1/4 mile 15 seconds
chevguy7 is offline   Reply With Quote
Old 08-18-2008, 04:11 PM   #4
kcjones
kcjones's Avatar
Thanks, Chevguy7, I appreciate the note on the 5" no c-notch required. I've decided to go with a 275/55/17 on 17x9x4.5bs on the rear and a 255/50/17 on 17x8x4bs on the front. That changes somethings, but I'm still hoping to get some opinions on the 1 piece driveshaft and "can I go 2 inch drop spring without the horrible caster problem?".
Kris
-Kris
Old 08-18-2008, 05:13 PM   #5
68Stepbed
68Stepbed's Avatar
I think your wheel/tire combo you have picked will look better. You can change to a one-peice drivshaft, but you might have to have one made. I think all long beds had two peice.
On the 2" drop spring question, again call ECE. Most folks with 1/2 tons are running 2" springs with little or no problems. I'm not sure if the 3/4 ton suspension is different or not.
Matt
Old 08-19-2008, 12:23 PM   #6
coggonobrien
3/4 ton hardware is interchangeable but spring rate wise nobody seems to have a 3/4 drop spring, all drops will be for 1/2 tons
coggonobrien is offline   Reply With Quote
Old 08-19-2008, 12:46 PM   #7
kcjones
kcjones's Avatar
I guess I'm hoping that even though I only have about 5.5" of clearance right now, if I go with a 1/2 ton 5" drop spring, it won't actually drop 5" from where it's at now. Hopefully it'll drop about 4-4.5" from where it's at now so I still have 1" clearance frame to axle tube.
-Kris
Old 08-19-2008, 12:50 PM   #8
michael bustamante
michael bustamante's Avatar
great lookin truck, Ive been thinkin of going just that same color. ECE website is very easy to navigate thru
1967custom
michael bustamante is offline   Reply With Quote
Old 09-02-2008, 11:29 AM   #9
kcjones
kcjones's Avatar
Thank you, gentlemen, I appreciate the answers.
-Kris
