manual transmission
I'm needing to know what manual transmissions will bolt up to a big block 400 in my '72?
its all about the +6 inches
Re: manual transmission
Anything that bolts up to a small block, inline 6, or 2.5 inline 4, will all bolt up to a big block.
most manual trannies will as long as u have the correct bellhousing, do u have a 402 bb or a 400 sb?
Trial and Error, its expensive but its a mistake i most likely wont make again 1971 chevy k10 custom deluxe http://67-72chevytrucks.com/vboard/s...d.php?t=341257 1968 chevy k/10 fleet http://67-72chevytrucks.com/vboard/s...d.php?t=334731 1948 desoto custom coupe fluid drive(family heirloom) |
Good deal, know where I can get the clutch pedal itself and other various needed parts? I'm converting my auto to a manual. LMC doesn't have the actual clutch pedal, just the parts for it.
its the big block, so i'm assuming the 402
Resident of Here
Do you want 2-3-4-5-6-speed?
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
4 or 5 would be perfect
Resident of Here
Tremec - http://www.ttcautomotive.com/English...cts/tremec.asp
Richmond Gear - http://www.richmondgear.com/ Classic Chevy 5-speed kits - http://www.classicchevy5speed.com/GM...tallation.aspx NV4500 - http://www.nv4500.com/
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() Last edited by thirdstreettito; 08-15-2008 at 10:58 PM. |
