![]() Join Date: Sep 2006
How are you cleaning parts?
How are you guys cleaning the really grimey parts like suspension? I want to clean and paint my front crossmember and arms while it's apart. I don't have a sand blaster. Wire wheel?
BRENT ![]() -'68 Stepside Project -'98 Z71 Daily Driver -Enough extra parts to build another truck and a half |
Re: How are you cleaning parts?
ive been using the foaming gunk parts cleaner and a pressure washer.
putty knife, wire wheel, brake cleaner or Easy Off oven cleaner (yellow can) always worked for me.......
1997 GMC Sierra Ext 1965 Mustang |
![]() Join Date: Jul 2008
Yeah,regular easy off or go to a detail shop and talk them out of some of their degreaser some kind of acid
Built chevy tuff! ![]() |
![]() Join Date: May 2008
Easy Off and a power washer
Mine is chopped, has a clutch, and a big block. |
Resident of Here
Wire brush, sandpaper, rag.
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
its all about the +6 inches
scraper first, then oven cleaner, then power washer.
If you don't have a power washer, you can go to the coin op car wash... just clean up after yourself. |
![]() Join Date: Jul 2007
"Grease Eater" works well to get the oily grease off the parts. Spray it on wait a while and hose or pressure wash it off. Some guys here are using it in their hot tanks to clean engine parts.
Costco usually has a good deal on it. It also works great to clean grease spots off garage floors and driveways and is biodegradable. |
I just did my whole front suspension. I used a pressure washer with degreaser. Then i used brake cleaner, rag, putty knife, and a wire brush. If i would do it again, i know for the amount i spent in cleaning chemicals and rags, i could have had my stuff blasted locally. I know a lot of us are on a budget, but it's worth looking into.
70 CST, 6.0/ 4L80E in the works. *Custom harness by 68 Short Step* |
The oven cleaner is the trick as said before just scrape off the big chuncks first and then let sit out in the weather to remove all the oil residue off the metal. I sent my frame out to the blaster once the thing was cleaned they wouldn't take it with grease on it.
That's weird, i talked to a guy about soda blasting, he told me i could bring it as is no pre cleaning required.
scrapping, wire wheel, degreaser then pressure cleaned!!!!
lots of patience!!
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild Last edited by big_al_71; 08-16-2008 at 10:53 PM. |
#13 |
Super clean, wire wheel, and lots of rags.
Cable -K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt -Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608 |
#14 |
Hope this doesnt cause an issue....
But heres a good how to that a buddy of mine posted on another forum http://www.blazinlow.com/forum/showt...t=rust+removal
1971 Chevy C10 LWB Shop Truck 1984 Chevy C30 Dually LWB Tow Pig 1985 Chevy K5 Blazer Last edited by dragginass; 08-16-2008 at 06:23 PM. |
#15 |
Resident of Here
dragginass, that looks really good. Effortless and effective! I still prefer something that takes less than a day.
#16 |
8 to 10 cans of 99 cent store oven degreaser, and a pressure washer. Takes a few applications but it works. May need a scraper in between applications.
#17 |
8 to 10 cans of degreaser....
or 3 to 4 cans of oven cleaner... try it... it works! |
#18 | |
Sophomore Member
![]() Join Date: Jul 2006
1972 Chevrolet Highlander SWB 1972 Custom Deluxe 3/4 2WD 60k miles these trucks don't need vacuum gauges cause they don't suck! two wrongs don't make a right, but three rights do make a left all i want is a little more than i'll ever get it's better to be judged by 12 than to be carried by 6 |
#19 |
I feel for you. I live in a semi crappy part of town, and the junk I see in the bays at the coin op always surprises me.
#20 |
Sophomore Member
i thought i had just about seen it all, until the other day i see a lady throw some quarters in the fragrance machine and commence to hose herself down with it! i didn't even want to go over and take a look at how bad she was. wow. sorry for the hijack.
#21 |
if i am gonna strip to metal to paint muratic acid but I DONT RECOMMEND it to others then i will hit it with phosphate of some kind..if i am dealing with rust i use this stuff. http://www.blulightning.com/
#22 |
Thanks for all the tips. I've used degreaser and a pressure washer but it didn't seem to do enough for me. Maybe I'm impatient. I'll try the oven cleaner.
#23 |
easy off the small parts and press washed i dipping my frame.
