Old 08-16-2008, 10:50 AM   #1
Nima
Blue 67
Upper control arm disassembely
Hey guys:
This question is not truck related actaullay, although the truck ones should be the same, therefore moderators please feel free to move it to proper place. I just didn't know where else to post it. Anyways, it is about a Nova. How do you take upper control arms apart to change the bushings after you takr thrm off of the car? Do you have to press the bushing out first? You know I am talking about the middle section of the upper control arm which bolts into the subframe. I hope I explained it right.
Thanks in advance.
1953 GMC 3/4 ton: current project
1967 C20: 5.3 voretc with T5 conversion, 4 wheel 8 lug disc brake
1972 Nova: my 4 door sport sedan! 5.3 voretc + T5 conversion. drivable project, FUN!!
1979 Camaro Z28: 5.3 vortec conversion with build TH350: drivable project, Fun to drive
1992 Camaro RS convertible (Z28 clone): 5.3 conversion with build T5: on going project
2005 Silverado 2500, 4x4 Duramax, original owner
Nima is offline   Reply With Quote
Old 08-16-2008, 12:46 PM   #2
SCOTI
SCOTI's Avatar
Re: Upper control arm disassembely
Originally Posted by Nima View Post
Hey guys:
Thanks in advance.
The a-arm is removed from the vehicle.
The nuts are removed from the ends of the control arm shaft.
The bushings are then pressed out of the a-arm & off of the shaft.
For bottom arms on cars, the bushings are just pressed out of the a-arm.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-16-2008, 04:17 PM   #3
Nima
Blue 67
This may sound stupid but how can you press out the bushing with the shaft in place? I have 20 ton shop press but nor much experience.
Old 08-16-2008, 04:26 PM   #4
SCOTI
SCOTI's Avatar
Not really because the shaft kind of gets in the way. I usually use an air chisel to wedge between the bushing shell & the a-arm working around the entire bushing a little @ a time. Once the first one is out, the shaft will come out & you could use your press on the second if you have the necessary adapters. Be careful because the stamped a-arms will collapse if you're not careful w/the press.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-16-2008, 06:51 PM   #5
Nima
Blue 67
I took them off. Thanks
