BIG CHEVY 3600 LONGBOX
American Autowire question??????????
I'm starting to wire my 51 truck. It has a 350 crate engine. The plug to the alt. wont fit my alt. The Wiring kit came with a plug in for the alternator that won't fit mine. The kit plug had two connects but my alt. has 4, one larger and three smaller.
If I were given 8 hours to chop down a large tree, I would spend the first 6 hours sharpening my ax. Abraham Lincoln http://s729.photobucket.com/albums/w...cpZZ3QQtppZZ20 |
Re: American Autowire question??????????
so whats the question?
call them and see whats up. |
"Who's on first"?
Does the Alt. that you have require a external regulator?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
I assume it has an internal regulator. It came with the GM crate 350 engine along with the power steer pump and air compressor.
I can't see any identifying numbers on it but I'll post a picture of it. Hopefully someone will be able to ID it.
Here are three pics of the alt. Hopefully someone will be able to ID it.
http://good-times.webshots.com/photo...99708909KcnIPb http://good-times.webshots.com/photo...99708909gxXEHM http://good-times.webshots.com/photo...99708909wolOOR
Big Chevy what you have is the newer cs130 alt used from 86-99. american autowire sells adapters to the earlier style alts, about $10
'56 Big window 350/700r4 9" rear w/disc |
Thanks: I just ordered the adapter, should be here in a few days. Cost 11.00
