Old 08-16-2008, 03:20 PM   #1
8bolt
Sandblaster Help
Hi I have a 110 lb or 20 gal pressurized abrasive blaster .I am using Black Beauty fine media with a 3.5mm ceramic nozzle. Compressor size is 5HP 60 gal tank 12,5 cfm@ 100psi. This thing is plugging up steady I use it for 15 to 30 seconds and it plugs the media seems to be dry the water trap has no water in it I have the air setting at 125 high 75 low. Thank you for any help.8bolt.
8bolt is offline   Reply With Quote
Old 08-16-2008, 06:11 PM   #2
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Re: Sandblaster Help
What are you blasting with Black Beauty? IO blasted my uncles wheels, chassis, and rear end.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 08-16-2008, 06:52 PM   #3
cdowns
cdowns's Avatar
did you screen the material b4 putting in the blaster?// did the pressure blaster come with instructions?does it have a choke valve?if its been used before ands its a cheaper harbor frieght type the hose coud be disintagrating and causing the clogges same is true of the blasting nozzle
Old 08-16-2008, 06:53 PM   #4
Fastfun
Fastfun's Avatar
I had the same problem and I started sifting the media before I put it in the pressure pot. I didn't have anymore problems.
Fastfun is offline   Reply With Quote
Old 08-16-2008, 08:02 PM   #5
8bolt
cdown it is a cheep 150.00 harbor freight blaster I pick up on holidays in Mn.I will check the hose and change the tip.
Old 08-16-2008, 08:05 PM   #6
8bolt
Hi fastfun what size screen did you use. Thanks 8bolt.
Old 08-16-2008, 08:08 PM   #7
8bolt
Sorry cdowns I forgot to say thank you . THANK YOU. 8bolt.
Old 08-16-2008, 08:14 PM   #8
8bolt
Hi thirdstreettito I am blasting my frame .
Old 08-17-2008, 06:30 AM   #9
72freak
Rottenwood Garage Member
72freak's Avatar
Mine did the same thing..........It especially clogs up when Its hot outside. Its the moisture. Put the water separator as far a way from the compressor as you can. Mine will still clogg a bit so every 2 min. I put my finger over the end of the gun and pull the trigger to back blow the media.
If I do that periodically it never cloggs.
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 08-17-2008, 08:49 AM   #10
Thealien
Thealien's Avatar
I do that with my blast cabinet. Works well.
Old 08-17-2008, 08:55 AM   #11
msgross
msgross's Avatar
If it's a pebble that clogging it then you need to sift the media or use a lrger tip. I used the same setup for my frame. The Black Beauty works well but does have a few large stones that will clog you up. The blaster will need more air pressure with the larger tip so adjust accordingly.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 08-17-2008, 09:47 AM   #12
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
8bolt,
I think all of the guys are right about the clogging issue. Sifting or screening your sand is definitely a must and you have to watch the moisture in the lines as it WILL clump your sand and clog your lines. I've have been having the same problems with my blaster. Get a Good Compressed Air Filter. I am now using the Motor Guard M-100. I have this setup in my garage for both my Sand Blaster and my Powder Coating Setup. I have not had any problems since.
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
