Old 08-16-2008, 04:29 PM   #1
RShaips
79 GMC 4WD No Dash Lights!
I recently bought a very clean 1979 GMC 1/2 Ton 4WD Short Step. The dash lights will not work, I have the dash off and there is no power going to the dash on the master plug. I have headlights, tailights, interior lights just no dash lights. The ground is good and everything looks right. Truck only has 70,000 original miles. Any ideas? Thanks
RShaips is offline   Reply With Quote
Old 08-16-2008, 09:00 PM   #2
Albatrossian
Georgia Boy
Albatrossian's Avatar
Re: 79 GMC 4WD No Dash Lights!
Could be the reostat on the headlight switch.. I'd check the wires going into the headlight switch plug.
Albatrossian is offline   Reply With Quote
Old 08-16-2008, 11:18 PM   #3
Walts_restoration
Real Projects never die
Walts_restoration's Avatar
check the fuse, did the same thing on my 77. removed the dash played with the headlight switch, blew a fuse lolol. Just replace it, hard to tell if a glass fuse is good, or use a test light if you have one.
Ill put it this way, ive got a few lawn ornaments
My name tag says Ryan
KansasTwister On other forums
Walts_restoration is offline   Reply With Quote
Old 08-17-2008, 12:55 AM   #4
Prong
How do the cluster bulbs look? Also, you might pull them out and pull the copper contacts out to create more tension so they have a firmer bite on that printed circuit.
Prong is offline   Reply With Quote
Old 08-17-2008, 10:08 AM   #5
RShaips
Everything looks great, The headlight switch is what I think it must be, when I turn it on and check the wires for power nothing new lights up, only the ones that have constant power light up. So I guess I need a new switch unless there is a way to fix mine? Thanks
Old 08-17-2008, 10:11 AM   #6
andresco50
andresco50's Avatar
The + cable is gray the switch send + to all the bulbs when you turn on the lights
2001 silverado 2wd
2003 silverado 4wd
1975 scottsdale c10 (project)
andresco50 is offline   Reply With Quote
Old 08-17-2008, 10:50 AM   #7
Walts_restoration
theres a fuse just for the dash lights, trust me i did the same thing in my 77 and had every light but dash lights. Have you checked the fuse? im just trying to get you to check it before you get too deep into something, replace the fuse if you dont know how to test it, saves the hassle of tearing everything apart.
Old 08-17-2008, 12:19 PM   #8
RShaips
All the fuses are good. Thanks
Old 08-17-2008, 06:09 PM   #9
79gmcsierragrande
Manual Transmission Club
79gmcsierragrande's Avatar
On my 79 the dimmer is the problem. If rotate the dimmer switch back and forth the lights go on and off. Eventual they will not work at all, I’m going to replace the light switch but I’m still figuring out what I’m going to do with the dash.
79 GMC Sierra Grande, SWB, Heavy Half
If I wanted easy I would just buy a NEW truck!
79gmcsierragrande is offline   Reply With Quote
Old 09-27-2008, 04:53 PM   #10
RShaips
Replaced the light switch and still nothing. The fuse and everything else looks good any ideas?
Old 09-27-2008, 05:43 PM   #11
f.monroe
f.monroe's Avatar
Check the fuse for the tail lights and or the brake lights . I cant remember which one . Better yet , turn on the lights and see if the tail lights are working and check the brake lights also .
Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 09-28-2008, 08:57 AM   #12
RShaips
Every one of my fuses and lights are good. I am not getting power to any of the dash lights and cannot find out why. Any one know which wire that feeds the gauge cluster is for the dash lights? I may try to use a different power source to get them to light up. Thanks
Old 09-28-2008, 11:36 AM   #13
blink32
blink32's Avatar
Sounds like you need to start at the fuse block and work your way out. I went through this and there isn't anything between the headlight switch and the cluster except wires. Did you volt out or test light the plug at the back of the cluster? Do the same with the headlight switch? When you pull the knob out on the light switch you should get at-least one new wire lighting up.
blink32 is offline   Reply With Quote
