Old 08-17-2008, 12:34 PM   #1
shortbed70
shortbed70's Avatar
How much drop?
How much of a drop in the rear does it take to get the axle to the frame? I am going to oreder rear springs for my 65 but I don't want to get to short of spring and be on the stops but then again I don't want it up in the air. I want the axle at the bottom of the frame at ride height. I will be putting a suicide doors bolt on notch on for clearence. I also have 2" blocks on the rear so I was thinking 4" springs for a total of 6" drop.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 08-17-2008, 11:28 PM   #2
gringoloco
A guy with a truck
gringoloco's Avatar
Re: How much drop?
6" Springs + 2" Blocks should get you where you want to be. The suicidedoors notch will not work- you will need one designed for the contoured frame. CPP, ART and McGaughy's offer bolt-ins for your frame.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 08-18-2008, 06:00 PM   #3
shortbed70
shortbed70's Avatar
Re: How much drop?
Ok and I also realized I can only go about 1" lower before I hit the bed floor so I am undecided if I'm going to take the time to raise the bed floor or what. Thanks
Troy
Big Red Dog build
Old 08-19-2008, 06:56 PM   #4
shortbed70
shortbed70's Avatar
Re: How much drop?
So 8" of total drop for the rear will set me where it is at now on the bumps with half trimmed?
Troy
Big Red Dog build
Old 08-20-2008, 05:40 PM   #5
gringoloco
A guy with a truck
gringoloco's Avatar
Re: How much drop?
I would start with the 6" drop springs and tweak it from there using blocks to suit your taste.
-Chris
