Old 08-17-2008, 02:23 PM   #1
ole school
ole school's Avatar
rear axle question
will a rear axle from a 74 chevy fit under a 72 gmc. if not what would be a good axle to put under it
IT'S HARD TO MAKE CHICKEN SALAD WHEN YOUR USING CHICKEN S.........
1968 crew cab build (under construction)
ole school is offline   Reply With Quote
Old 08-17-2008, 04:02 PM   #2
BarryB
BarryB's Avatar
Re: rear axle question
If your 72 is a leaf sprng truck, it should fit without much trouble, if any at all. If your 72 is coil spring than there will be some cutting and welding to get it to fit properly.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
