Old 08-17-2008, 02:49 PM   #1
64c20crewcab
64c20crewcab's Avatar
Oil for Ratio Adapter...
My speedometer was not working right (needle dancing). Gonna lube the cable and I took off the Stewart-Warner ratio adapter that was attached to the trans. It needed a good cleanup outside and in. Inside was caked with what seems to be old lube of some sort. It was really caked in there. Any ideas as to what type of lube/oil I should load this up with. Thanks!
..............................._________
......___________//___[[___{\ _____
...../__(_(O)_)___/____/____/_(O)_/
1964 C20 Long Stepside 3 Door Crew Cab
- Armbruster-Stageway Conversion
Y2K INDN Chief
"ONE OF A KIND, NOT ONE OF THE CROWD"
Aug 2010 - Front end frame cleanup & engine swap done!!!
June 2011 - Rear end bagged
Sept 2011 - Rebuild motor top end
Sept 2012 - Parked and slowly working on it.
Aug 2013 - Front end bagged - finally!
Aug 2014 - Stepside swap conversion done. Finally ready to start bodywork! Have a few KEWL ideas...
Here is my build thread:
http://www.67-72chevytrucks.com/vboa...d.php?t=335427
64c20crewcab is offline   Reply With Quote
Old 08-17-2008, 08:08 PM   #2
66Gilbert
1966 Crew Cab & 4X4 Fanatic
66Gilbert's Avatar
Re: Oil for Ratio Adapter...
When I worked for a bulk cement trucking company 12 years ago, I use to build these ratio boxes all the time. I used Citgo, Mystic JT-6 grease, multi purpose. I think they have synthetic blends now that are better but are more expensive. This grease worked well for me as most of the ratio boxes went 250,000 to 300,000 miles with no problems. Also I noticed it doesn't have a gasket, It needs to be sealed or it will fail.
66Gilbert is offline   Reply With Quote
