New Member
FS: Dual Front Shock Brackets 67-87 GM
Brackets for a dual front shock setup for 67-87 1/2 and 3/4 ton Chevy or GMC 4x4. You would need to supply a longer bolt and spacer for the bottom. Just need cleaned and painted, $25 shipped.
New Member
Re: FS: Dual Front Shock Brackets 67-87 GM
$20 shipped
What exaclty is needed for the bottom? It's tough to tell from the picture. Is is just a longer bolt and what sort of spacer?
Would you go $15 shipped to 84037? Thanks. |
New Member
The stock single shock mounts inside the lower shock mount. With the dual setup the shocks mount on the outside of the lower mount, one on each side. So you need a longer bolt and some kind of spacer so when you tighten up the lower shocks the mount sandwiched in between the two shocks doesn't want to colapse. I would do $15 shipped.
Drunkbus,
Lets do it. Send me a PM for how you want payment and I can send you my particulars. Thanks. |
New Member
PM sent
Paypal sent! Thanks.
do U still have these brackets?? if so I want em. OK
Glen Madsen 200 N JOrdan MIles City MT 59301 406-234-0441 |
darn didnt read far enough!! any one else got any brackets like these or the other stile is prefered??
