Old 08-17-2008, 04:24 PM   #1
protrash64
Resistance is Futile
protrash64's Avatar
Stock control arms + bags question.....
Ive seen many cool set-ups here and didnt find an answer searching for info so heres the question.
Do the stock front bump-stop mounts NEED to be removed to work with bags?
I am using Re7's with cups in 73-87 type stock control arms.......I do not have my spindles mounted and the bags really fight back. They are pushing the cups out against the bumpstop mounts.....should they be removed? I was planning on using the stock bump mount to limit my travel for the time being. It may be ok to leave the stock bump mounts once I jack up the arm and mount my spindles, but it would be simple to get rid of them now and not go backwards.....this project has taken me long enough as it is.
Any suggestions would be appreciated as I have to run my lines and do other things to complete the install; Im going to check this later and see what everyone has to say about it.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 08-17-2008, 06:30 PM   #2
72Ls1Truck
Re: Stock control arms + bags question.....
I had interferance issues on my '77. I did remove the lower bump stops from the control arms. I bought after market bumps and moved them outwards away from the bag. With a 2.5" drop spindles I would lay my front down on the control arms without the use of a bump.
72Ls1Truck is offline   Reply With Quote
Old 08-17-2008, 07:19 PM   #3
scotts62
One day...
scotts62's Avatar
I just took mine out just so they wouldnt be in the way and it would drop a little more.
There are one 4 or 5 spot welds on them and they come right off
Scott
93 crew cab build
Project 62
Old 08-17-2008, 09:56 PM   #4
bagged69c10
soon to be bagged64sub
bagged69c10's Avatar
Ive always taken them off. Its much easier at this point. But Ive never wanted to limit the travel.
1969 c-10, bagged, Zd, 20" Boyds SOLD!
1964 Suburban COMING SOON Build threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=304726
1965 c-10 long bed
1993 Sierra x-cab
1999 tahoe-4/5 on 22s
2005 Chevy work truck
bagged69c10 is offline   Reply With Quote
Old 08-17-2008, 11:07 PM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
I suggest that you add your own stops once you know where you want them to be. If you blow a line or bag it's much nicer to ride on a stop rather than metal to metal.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-19-2008, 08:40 AM   #6
protrash64
protrash64's Avatar
.....thanks for the replies. Yeah, I would agree w/ everyone. My bumpstops are now sittin on the trash pile. After jcking up the control arm I started to get interference about 1/2 way up the travel and so I drilled 'em and knocked them off.
Old 08-19-2008, 02:58 PM   #7
BigSky71
LAIDOUT
BigSky71's Avatar
I agree with that, put the suspension together and determine where your stops need to be. I made stops that are mounted an inch down from the cross member to keep my tires from touching the inner fenders if I lost air...
67 2wd Shorty
Build Pictures
BigSky71 is offline   Reply With Quote
Old 08-19-2008, 03:34 PM   #8
Riveted1
Tasty Cakes!
Riveted1's Avatar
I took out the bumpstops but left part of the steering stops in.
I'm a little and a lot
Ground beef: A cow with no legs.
'66 Chevy SWB "Penny"
'67 Chevy Big Window SWB- aka "Pearl"
'72 Burb- "Betty" "It's not a hearse dammit"
'99 Chevy Ext. cab Silverado
Riveted1 is offline   Reply With Quote
