2002 z71 "noise"
I have a 02 GMC ex-cab Z-71 that has a REALLY annoying sound coming from the driver side front end. You can feel it in the steering wheel, you can hear it when you hit a bump, and it honestly sounds like the front wheel is going to fall off when you hit the smallest bump. I have looked underneath it for anything obviously loose and cannot find anything. I thought it was maybe my nerf bars but I climbed under it and tightened them down as tight as humanly possible. It is driving me nuts!!!!
![]() Anyone have any ideas of what to look for?
1970 Gmc Grande Sierra Swb 2wd LSX (LQ4/4L80e) 1990 K1500 Daily ![]() |
![]() Join Date: Jan 2003
Re: 2002 z71 "noise"
I don't know if it is the same thing, but my stepdad's 04 has a popping/squeaking noise from the driver's front that came be felt in the wheel. It feels like something is loose and banging around. It happens worse in left turns. He did some research (and I think I found it on this forum) that there is an issue the the steering shaft under the hood. I think there was something about changing it to a shaft from a HD model. That is to the best of my memory. If I'm wrong, someone correct me, its been a while since we spoke about it.
1998 GMC Sierra SLE 1/2 ton 2WD 305 Vortec -Gibson Stainless Cat Back Swept Side -SS Wheels 2005 Honda CRF250R 2006 Honda CRF150F Last edited by bwood; 08-18-2008 at 10:05 PM. |
Was it a recall? I'm afraid of taking it to the dealership and them sticking it to me.
He's got mean nasty FANGS!
![]() Join Date: Dec 1999
It isn't a recall although it should be. Our 03 Yukon and 06 Silverado have both had the new design shaft installed. They're around $100 and most dealers will charge $45-90 to install it. Depending on how many miles your truck has and how many owners it's had GM may pay for all or part of the shaft if you cause enough stink.
Josh
2004 K2500 Burb 1999 C3500 1985 Cutlass Supreme 1969 C-10 1967 C-10 Panel josh@67-72chevytrucks.com |
