Old 08-18-2008, 09:41 AM   #1
6768chevylover
6768chevylover's Avatar
Power Steering Problem
I ahve A 67 chevy 1/2 ton truck that had manual steering. I took a pwr steering box off a 71 chevy to convert mine to pwr steering. when I tried to mount it the box was hitting the frame in between the mounting holes, so its not mounting flush. has anyone had this problem? and if you know how to fix it? id put spacers in it but i dont know if that would be safe. any help is appreciated. thanks!
6768chevylover is offline   Reply With Quote
Old 08-18-2008, 12:24 PM   #2
Custom 68
Custom 68's Avatar
Re: Power Steering Problem
you might search around on here some it may even be in the FAQ section but yes the frame is different for power streering vs manual. Most people I believe will heat and dimple the area where the box goes to make it fit in the frame. I have not done this but remember reading about it.
Good luck
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 08-21-2008, 12:00 AM   #3
Augy's '53
Augy's '53's Avatar
Check out Classic Performance Products tech articles.
Augy's '53 is offline   Reply With Quote
Old 08-21-2008, 09:02 AM   #4
MotorSeven
Restoration Desperation
MotorSeven's Avatar
You should only have to notch the bumper bracket. That is what kept the steering box from moving forward enought to line up on my '68. I just removed the bumper bolt at the frame & it is still hanging there waiting for me to grind the notch & re-bolt.
RD
MotorSeven is offline   Reply With Quote
Old 08-21-2008, 09:21 PM   #5
70C10Toejam
Hellasick
70C10Toejam's Avatar
check this thread out...might be some help. know there are better pics somewhere, but cant find them yet.
http://67-72chevytrucks.com/vboard/s...d.php?t=255352
found another thread
http://67-72chevytrucks.com/vboard/s...d.php?t=192229
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes)
This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do.
RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!!
BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys
70C10Toejam is offline   Reply With Quote
Old 09-03-2008, 10:16 AM   #6
6768chevylover
thanks for the info everyones giving me. Does anyone who has spaced there box out if they know about how much of a space and where I can get spacers to do it. thanks again.
