Old 08-18-2008, 01:39 PM   #1
JCampbell
Gas Guage/Int Light Issues
I've developed a problem lately and I'm not sure where it stems from or when exactly it started. When I turn on my lights, my dash lights don't come on, my gas gauge stops working (needle drops to 'e'), and my high beam indicator turns on for low beams/goes off when I hit the high beams.
Any ideas? I tore the dash apart this weekend to look for the obvious, but to no avail. Headlight switch maybe?
JCampbell is offline   Reply With Quote
Old 08-18-2008, 02:43 PM   #2
swb85
On a budget like Fred Sanford
swb85's Avatar
Re: Gas Guage/Int Light Issues
Probably a problem with the printed circuit on the cluster. Mine was doing a very similar deal when I bought it (gas gauge only worked with headlights off). I got fed up and replaced the whole cluster with autometer gauges.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 08-18-2008, 03:28 PM   #3
JCampbell
I thought about that too.
Old 08-20-2008, 10:32 AM   #4
JCampbell
Nobody's ever experienced this before? C'mon.
Guess I'll start at the headlight switch.
Old 08-20-2008, 11:13 AM   #5
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Assuming everything worked properly prior to all this, what electrical changes have been made to the truck? My first though is a short and printed circuit.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 08-20-2008, 11:53 AM   #6
wedgemon
wedgemon's Avatar
Check for shorted wires - i/e: screws thru or wear spots along the affected circuits.
I had a '83 GMC, push in the cig lighter and the dome light would come on. Turns out that the lighter fuse was replaced oversized and melted the shared circuit wiring to the floor - along the driver side run to the dome light. It was kinda cool though... Hated fixing it.
- Dave
2003 Silverado K1500 Z71 - Arrival Blue
1973 K5 Cheyenne Blazer 350/TH350/NP203
Kids Trucks:92 K1500 Blazer 5.7/700R4 4" lift.
RETIRED: 1980 Scottsdale 4x4
Founding Member:
"TILT WHEEL BELLY." Club
wedgemon is offline   Reply With Quote
Old 08-20-2008, 12:13 PM   #7
JCampbell
Nothing. No electrical changes.
I'll take a peek at the circut.
Old 08-20-2008, 02:38 PM   #8
Captkaos
Captkaos's Avatar
Check the fuses like Dave said also. And check your grounds on the upper left under the dash. I had my interior lights blow out when I hit the brakes regularly, ended up being a lost ground.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
