Old 08-18-2008, 05:57 PM   #1
lyrikz
PITbut
lyrikz's Avatar
What thermostat do i need?
I have an edelbrock performer intake. I need a thermostat. I went to napa and they gave me this thermostat, but it doesnt fit IN the thermostat, the thermo bolts OVER the thermostat. That doesnt seem right... There are little notches on the thermostat housing, i figured the thermo fits in there then bolts down with a gasket. Mr Napa disagrees....
Anyone have a part # for me??? Its a chev 454....
lyrikz is offline   Reply With Quote
Old 08-18-2008, 06:16 PM   #2
Senator350
Senator350's Avatar
Re: What thermostat do i need?
thermostat sits in the intake, then gasket, then water neck
RN U OVR
Senator350 is offline   Reply With Quote
Old 08-18-2008, 06:24 PM   #3
lyrikz
PITbut
lyrikz's Avatar
It sits INSIDE the intake right... this thermo didnt.. I need to know what one to order...
Old 08-18-2008, 06:27 PM   #4
Senator350
Senator350's Avatar
mmm it doesn't really fit IN the intake... it just sits flush on the opening.
RN U OVR
Old 08-18-2008, 06:41 PM   #5
lyrikz
PITbut
lyrikz's Avatar
ahhh ok.. So it sits ON the intake, then the gasket, then the top housing????
Old 08-18-2008, 06:56 PM   #6
Senator350
Senator350's Avatar
you got it! should work out fine for you.
are you coating the gasket with permatex?
RN U OVR
Old 08-18-2008, 07:42 PM   #7
lyrikz
PITbut
lyrikz's Avatar
WEll, the thermostat should fit INNNN the waterneck, then bolt on the intake manifold correct????
THe waterneck im getting comes with the o-ring setup so no leaking...
This thermostat that they are trying to sell me does NOT fit inside the water neck... It would basically sandwhich in between the neck and the intake.. I know thats not right, but they swear it is..... The thermo should sit IN the neck on the little lip and then mount on the intake... Im pretty sure of that...
Old 08-18-2008, 07:48 PM   #8
Senator350
Senator350's Avatar
ok. nevermind
RN U OVR
Old 08-18-2008, 07:50 PM   #9
lyrikz
PITbut
lyrikz's Avatar
ok. nevermind
Am i on the right track. or am i wrong. ahah Im talking with the napa guy and he says he is right. I dont think he is...
Am i senator??? The thermo has to fit in the waterneck right?
Old 08-18-2008, 08:01 PM   #10
Senator350
Senator350's Avatar
dude. the napa guy is right.
the thermo just sits on top of the manifold.
i swear... if you make me go unbolt my water neck to take pictures to show you, i'm going to charge you for a new gasket!
RN U OVR
Old 08-18-2008, 08:01 PM   #11
Senator350
Senator350's Avatar
can ANYONE with ANY SBC or BBC please chime in here!!! helloooo!!!!
RN U OVR
Old 08-18-2008, 08:20 PM   #12
lyrikz
PITbut
lyrikz's Avatar
hahahah...
SO he is right??? The thermostat doesnt go INSIDE the water neck?? Thats where im stuck. ON my stock waterneck, the thermo sits INSIDE the waterneck so its flush on top of the intake.... ahaha I have a gasket sitting here. I will mail you a gasket if you verify this for me....
Old 08-18-2008, 08:46 PM   #13
lyrikz
PITbut
lyrikz's Avatar
Originally Posted by lyrikz View Post
hahahah...
Ok, i drew some pictures. ahaha... Hope this explains whats going on...
ahaha let me know.... Thanks for your time to senator. The red is the thermostat, the block is the intake mani.
Old 08-19-2008, 01:50 PM   #14
lyrikz
PITbut
lyrikz's Avatar
Anyone??? I drew that work of art and no responses. ahahah.. anyone..
Old 08-19-2008, 02:04 PM   #15
72hotrod
72hotrod's Avatar
Manifold has depression for t-stat to sit into, housing is flat at mating surface on mark IV BBC. Don't know about later versions.
72hotrod is offline   Reply With Quote
Old 08-19-2008, 05:15 PM   #16
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Thumbs up Re: What thermostat do i need?
Yes the NAPA guy is correct, it does not go into the t stat housing it sets on the block. The newer Chevys go into the housing, some are actually built into it.
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 08-19-2008, 06:04 PM   #17
michael bustamante
michael bustamante's Avatar
on my performer theres a recessed lip where my t stat sits in, then the gasket goes over, then the housing, mine does not "sit on top" like NAPA says. Your Performer should have the same recessed area in the t stat hole
1967custom
michael bustamante is offline   Reply With Quote
Old 08-19-2008, 06:22 PM   #18
lyrikz
PITbut
lyrikz's Avatar
My 81 bbc the stock thermostat sits in the housing. I cant reuse my ugly old thermostat housing...
On my manifold there is NO place for it to set in, its completely flat. the water neck has a recession where the tstat fits into... Michael, do you have a part number for your tstat, or what did you order yours for...?
Old 08-19-2008, 09:22 PM   #19
71tahoe
71tahoe's Avatar
Then you have a defective intake. Is this a pre 86 motor? It should have a recess the same diameter and thickness as the disc part of the thermostat.
71tahoe is offline   Reply With Quote
Old 08-19-2008, 11:07 PM   #20
petey-pablo
"THE GREEN GOBLIN"
petey-pablo's Avatar
Question Re: What thermostat do i need?
Does anyone have actual Pictures of these two types I am confuesed Now haha makes me wanna go take mine apart I just installed it last week On My 454BBC ! Sorry I had to ask! But it would be nice to see these two types. I have my old set up I took off I can take a picture and post it in the morning If you need it... I just added a picture of my old waterneck setup on my 454bbc. changed it out...
Petey-pablo
"THE GREEN GOBLIN"
1972 Cheyenne 10 Short Fleet Side
Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs.
454BBC TH400,Posi
1971 Cheyenne 10 Long Fleet Side
454BBC TH350,Posi Sold
Drive it like you stole it!
Petey-pablo@sbcglobal.net
petey-pablo is offline   Reply With Quote
Old 08-19-2008, 11:24 PM   #21
lyrikz
PITbut
lyrikz's Avatar
Its an 81 bbc. The intake is a new edelbrock. THere is no idention or anything like that. No lip for a thermo to sit in. The waterneck/thermo housing has a lip that the thermostat sits in. All i need to know is what thermostat. ahaha..
Im just going to bring my waterneck into napa, and have him get me one that fits in the waterneck and problem solved...
Old 08-20-2008, 12:00 AM   #22
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Big block Edelbrock, top, is smooth...small block stock manifold, lower, is stepped. The water neck fits both. I suspect that you might need a different water neck for the big block intake. I thought they were both the same...learn something new every day...LOL! My small block Edelbrock, not shown, has the recess in the manifold just the stock small block manifold.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 08-20-2008, 12:29 AM   #23
lyrikz
PITbut
lyrikz's Avatar
Ya, the waterneck has the recess for the thermostat. I just need a smaller thermostat that fits IN the waterneck and ON the mani like that ugly picture i drew....
I just dont know what thermo to order.... I will just go to schucks or napa with the waterneck and fit one.....
Old 08-20-2008, 04:45 AM   #24
71tahoe
71tahoe's Avatar
I have no experience with the BBC so I learned something new too
Old 08-20-2008, 11:23 AM   #25
michael bustamante
mine is just a standard, t stat fom auto zone 180 degrees, I got the higher priced one. I just asked for a t stat for a 79 chevy truck(doner truck) 350 motor 4 barrel. I did not mention the performer intake. sorry I dont have the part # though.
1967custom
