Old 08-18-2008, 08:01 PM   #1
edin355
need info on relay
I recently purchased a 72 swb Ac truck.Im in the process of redoing some of the wiring.Ac cabs are new to me.Next to the horn relay under the dash in another relay with a red,blue,black,andb/w wires. They run into the engine compartment about two foot long and then they were cut off.I have searched books with wiring diagrams but cant find anything showint this relay.Im almost sure it has to do with the ac.I would think maybe it was cut from the wiring hub where the main wires are joined,but dont know for sure. Any help would be greatly appreciated. Thanks for any help. edin 355
edin355 is offline   Reply With Quote
Old 08-19-2008, 01:11 PM   #2
edin355
Re: need info on relay
Could someone with AC please give me some in sight on this problem.
Old 08-19-2008, 02:29 PM   #3
Hutch
Hutch's Avatar
edin355
Here is a link to a wiring diagram:
http://67-72chevytrucks.com/vboard/s...d.php?t=185665
From your description I do not think that the relay you are describing has anything to do with the A/C.
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
Old 08-19-2008, 02:42 PM   #4
463
463's Avatar
Justin has the wiring dia here. http://67-72chevytrucks.com/vboard/s...=185856&page=5 the wire you list red,blue, black and b/w tells me that it was hooked to a after market realy like a bosh unit to run a higher curent device.
Trueman
463 is offline   Reply With Quote
Old 08-19-2008, 04:25 PM   #5
neonlarry
neonlarry's Avatar
Is the relay simular in appearance to the horn relay? If so my best guess is that it is the TCS (transmission controlled spark) relay.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 08-19-2008, 07:02 PM   #6
463
463's Avatar
this 72 truck would not have had a tcs,
Trueman
Old 08-19-2008, 08:04 PM   #7
Big Block
Big Block
Big Block's Avatar
The relay is for your a/c compressor. If you are going to try to use the original a/c unit you will need to get the under hood a/c harness
Big Block is offline   Reply With Quote
Old 08-19-2008, 08:09 PM   #8
JimKshortstep4x4
As mentioned it is probably an after market relay setup as the other relay it could have been is the anti-dieseling relay which was located close to the heater controls. The wires to the anti-dieseling relay were pink, dark green and orange. The relay for the AC unit should be mounted on the heater box by the passenger's side.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 08-20-2008, 01:07 PM   #9
edin355
Thanks for the info. This has to be a stock relay.I saw one on a 72 blazer located in the same place.It goes out to the engine bay through a plug above the fuse box. The one on the blazer has been cut off at about two foot also.So because of the plug and the way the wiring was wrapped I know it must be a stock item on ac units.Someone on this board with ac must have one like this.I greatly appreciate all of the feed back so far.Still looking for someone with ac that has this relay on their truck. Thanks for any and all help.
Old 08-20-2008, 01:14 PM   #10
edin355
Bigblock you said something about being used with ac compressor.If so do you know where it is wired to?I would like to make up any wiring harness that I might need.
Old 08-20-2008, 08:01 PM   #11
JimKshortstep4x4
The relay is part of the TCS system as Neon Larry mentioned. It sounds like the system has been eliminated so you will not need the relay.
I have seen the relays on Blazers but not on trucks.
Jim
