08-18-2008, 10:03 PM | #1 |
hood hinge? can't get her aligned
I've adjusted the trailing bolt on the passenger hinge to try and pull the hood down flush, but still not there. If I push on the hood, it will almost sit flush, is the hinge shot or what??!! Any suggestions are greatly appreciated.
___________ Greubin '71 C20 custom - GM Crate 350CI/290HP, BTO 700R4 level II, Qjet, and HEI |
08-18-2008, 10:07 PM | #2 |
Prestige Worldwide
Re: hood hinge? can't get her aligned
This usually means that your springs are worn out.
08-18-2008, 10:08 PM | #3 |
Mine does the same thing - some day I'll replace the hinges.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD Click here to support the board Philippians 4: 6-7 |
08-18-2008, 10:12 PM | #4 |
its all about the +6 inches
worn springs and/or hinges.
A band aid fix, loosen the 3 bolts that hold the hinge to the fender, now puth the hood up, as in opening it further than it is supposed to go. Not a lot of force, just enough to pivit the hinge. While holding in the 'further up' position, tighten the bolts back down. Very slowly lower the hood once the bolts are tight. Watch the rear edge of the hood, it may come in contact with the cowl panel. If it gets close, or actually touches, then loosen the hinge to hood bolts and pull it away. This will snug the rear of the hood down once you get it ballanced out. |
08-18-2008, 10:36 PM | #5 |
Firefighter
Just like Longhorn said^^^^^^
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA |
08-18-2008, 11:30 PM | #6 | |
08-19-2008, 06:05 AM | #7 |
'71 chevy s.bed/s.side
Before you replace that hinge, spray all pivot points good with a spray lube such as white lithium grease. Work the hood up and down several times and spray it again. Try that before replacing the hinge.
If you have to buy a new hinge, get a genuine GM hinge & spring, they're still available!
STILL PLAYS WITH CARS...AND TRUCKS!! Parents! Be good to your kids...they get to choose your nursing home! 250 I-6 with a 3 speed Saginaw and Borg Warner Overdrive...She's got overdrive! Last edited by Botietruck; 08-19-2008 at 06:06 AM. |
08-19-2008, 07:02 AM | #8 |
Had the same problem with mine, new hinges solved the problem AND they are still available from the General pt#'s 3911705 left, 3911706 right
08-19-2008, 11:15 AM | #9 | |
The LH hinge was $13 more than the RH one, I wonder if they're a little harder to find (not as many left)? A little expensive, but I've needed new hinges for years. Maybe my hood will lay flat without my help now
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 08-19-2008 at 11:15 AM. |
08-19-2008, 03:07 PM | #10 |
Are these #'s for the whole assembly or did you have to resuse your old springs?
Baby Blue's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=652776 Project 68's Build Thread: http://67-72chevytrucks.com/vboard/s...17#post8442117 www.stonecolumnclassics.com Email: Josh@stonecolumnclassics.com |
08-19-2008, 09:49 PM | #11 |
big guy
let us know how you make out with gm direct and if it helps with your hood trouble. I am having the same thing going on with my hood. Have you used Gm direct before? if so how are they? there prices didn't look all that bad.
thanks Ray |
08-19-2008, 10:14 PM | #12 |
love the color
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
08-19-2008, 10:21 PM | #13 |
08-19-2008, 10:25 PM | #14 |
08-20-2008, 07:51 AM | #15 |
This will be the first "classic" parts I've bought from them, but I've bought a few things for my silverado from them and shipping was fairly quick. They're prices are *usually* a good bit lower than a dealer, but then the slap ya with about $10 shipping for each item, but if you don't live in NC, no tax, so it could be a wash I'll usually call our local dealer first with the PN's (they won't take orders over the phone, so I just call and ask for the prices) then compare to GMPD and they're usually a good bit cheaper. Normally, the dealer has to order stuff anyway, so you've got to wait anyway.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 08-20-2008 at 07:55 AM. |
08-20-2008, 01:33 PM | #16 |
Old member
Just talked to the local dealer they can't pull a picture of them to see if the spring comes with it but the prices are $99.00 for LEFT and $78.00 RIGHT.
I'll buy the powder coated ones off E-bay for $99.00 before I pay that much. LMC price in the summer book is $39.95 each. without springs. Spring kit has both springs in it for $19.95. So $60.00+ shipping from LMC.
08-20-2008, 02:13 PM | #17 |
Andy, that's why I used GMpartsdirect.com. I paid $131 SHIPPED and shipping was $22 of that. I've read too many horror stories on here about the aftermarket stuff. This should be a "one time" buy for me. Certain things I'll cheap out on, but good hood hinges aren't one of them. Hopefully I'll get another 40 years out of 'em.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 08-20-2008 at 02:15 PM. |
08-20-2008, 07:06 PM | #18 |
I am a Referee of life.
The aftermarket hood hinges I have seen seem inferior.I haven't used a set and would probably buy GM since I have heard bad about the aftermarket ones.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
08-20-2008, 08:44 PM | #19 |
big guy
Hey Redneck
Thanks for the feed back! I have to tell you i just sat here and read all ten pages of your build and man your a hard worker, and you did a really nice job on that truck! it looks sweet Thanks again Ray |
08-27-2008, 10:03 PM | #20 | |
Got my hinges today... DEFINITELY NOS. Although I was hopeful, I had a feeling they were "hinges only," which they were... I couldn't find springs listed on GMpartsdirect.com. Are the 73-87 springs exactly the same (I have no idea, just throwin' that out there.) Soooo..... who sells GOOD hood springs?
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
08-28-2008, 06:33 AM | #21 |
big guy
Your crazy!!!!! but i understand that is the funny part. there is something about these old cars and trucks they keep begging us to make them better.
give it hell my friend, take it apart and have some fun, that is what it's all about. Ray |
08-28-2008, 06:46 AM | #22 |
Old member
Computer shopping again.
Says orignal GM hinges. http://www.brotherstrucks.com/prodin...number=HNG7200 http://www.lategreatchevy.com/produc...dept%5Fid=1457
09-02-2008, 04:44 PM | #23 | |
Thanks,
09-02-2008, 05:15 PM | #24 |
All parts are listed as veiwed from the drivers seat.At least that's what I've been told.It's always worked for me.
09-03-2008, 10:20 AM | #25 |
Old member
I agree looking from the drivers seat.
