Old 08-18-2008, 11:22 PM   #1
TimE
Hey Y'all!!
TimE's Avatar
Simple Drop Spindle Question
What's the difference between a drop spindle that says it fits 71-72 versus one that says it fits 73-87???
Background info...My '64 has spindles/rotors off of a 77 c10 and I used the tie rod sleeve/adapter from CPP to attach the steering to the spindle and used the 73-up ball joints. Which type of spindle do I need to focus on?
The reason for the question is I found a set of spindles for a decent price but they state they are for a 71-72 C10.
TimE is offline   Reply With Quote
Old 08-19-2008, 07:19 AM   #2
jlaird
jlaird's Avatar
Re: Simple Drop Spindle Question
ball joint size.
jlaird is offline   Reply With Quote
Old 08-19-2008, 09:34 AM   #3
hotrodhomi
hotrodhomi's Avatar
I thought the tie rod ends were different. I'm pretty sure you can make either one work though.
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 08-19-2008, 10:48 AM   #4
TimE
Hey Y'all!!
TimE's Avatar
So since I am using 73-up ball joints and tie rod ends I need to go with a 73-up spindle?
Old 08-19-2008, 11:32 AM   #5
hotrodhomi
hotrodhomi's Avatar
unless you change the mentioned parts.
'66 impala ht
Old 08-19-2008, 01:38 PM   #6
gringoloco
A guy with a truck
gringoloco's Avatar
You will have to change the upper ball joints and outer tie-rods. The lower ball joints are the same. The outer tie-rods will thread into your current adjusters and the upper ball joints will bolt in place of your current ones. If you already have discs, all the brake hardware will swap over(assuming 1.25" thick rotors).
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 08-19-2008, 02:42 PM   #7
TimE
Hey Y'all!!
TimE's Avatar
Thanks for the details Gringo! I do have the 1.25 rotors on there already with 3" drop springs. I am going to do bags and I want to do spindles at the same time to get it as low as I can without MAJOR issues(for now).
Old 08-20-2008, 12:26 AM   #8
RunninLo
3DrDwn--the 'burb not the band
RunninLo's Avatar
TimE,
Unless you're getting a steal I'd try to go with 73+. Certain vendors offer the 73+ in a 3" drop but the most I've found for 71-72 is 2.5"
I originally went with 72 parts for my 72 but now have to change out my spindles,TRE's and upper BJ's despite miy current set-up having 0 miles because I want to tuck big rims and need that extra .5" at the spindle.
IMO you'd be better off with 73+ than getting a discount on spindles and having to spend to convert for them to fit only to get in my shoes and want that extra drop.
Josh
Slo and Lo that is the tempo.
'72 burb build page here:
http://67-72chevytrucks.com/vboard/s...d.php?t=259256
'89 GMC Dually crew build page coming soon.
88 4x4 crew DD
duallys past/present pics here:
http://67-72chevytrucks.com/vboard/s...46#post4001246
89 1 ton Dually rear flip kit install here:
http://67-72chevytrucks.com/vboard/s...d.php?t=354327
RunninLo is offline   Reply With Quote
Old 08-20-2008, 12:45 AM   #9
TimE
Hey Y'all!!
TimE's Avatar
Thanks for the input Josh. I am going to wait and get a set for 73-up. My front suspension has very little miles on it too, so it would be silly to buy the "wrong" parts for my setup. I am curious though, are the 3" spindles worth the extra .5"? It won't cause any issues with alignment, etc.? I also assume that 15" wheels would be out?
Old 08-20-2008, 05:38 PM   #10
gringoloco
A guy with a truck
gringoloco's Avatar
15s will work with them, but you don't want more than about 3.5" backspacing, which sticks them out pretty far depending on wheel width...
-Chris
Old 08-21-2008, 07:56 PM   #11
RunninLo
RunninLo's Avatar
I'm trying to keep my frame planted while upgrading to a 22-24" rim. my 20's are more than fine with my current set up because I have TINY rubber on them but will gain overall outside diameter in the plus sizing unless someone makes a 22 or 24" tire with a 27" diameter.
If you're not sweating layin frame then it's not too big a deal. My philosophy is it's easier to change height with different cups/ bag spacers and have the ability to go low than have to swap spindles for that much needed .5"
Wish I had that thought a few years ago. I'll be damned if I'll even consider altering my DM or ART arms though so if I want it bad enough I'll swap spindles.
Josh
88 4x4 crew DD
Old 08-22-2008, 12:37 AM   #12
hotrodhomi
hotrodhomi's Avatar
I heard that most 3" spindles are really 2.5". Any truth to that? I bought 3" djm spindles, but I didn't really compare them when I put them in.
'66 impala ht
