Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 08-18-2008, 11:52 PM   #1
71Dragtruck
71Dragtruck's Avatar
New toy.
Installed a F.A.S.T wide band dual sensor air/fuel ratio monitor.
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 08-19-2008, 09:41 AM   #2
bigjimzlll
bigjimzlll's Avatar
Re: New toy.
I've got the alky one on order. How do you like it?
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 08-19-2008, 10:57 AM   #3
71Dragtruck
Re: New toy.
Just got it installed last night haven't had a chance to run it. Hope to try it out tonight, one thing I'm waiting to see is what the life span on the sensors will be running 1/2 C12 fuel and constent monitoring as I plan on leaving it installed, half the price of the unit is the wide band sensors.
What brand did you order Jim? This one can run both types of fuel.
Sponsored by:
Hard Candy Customs
Old 08-19-2008, 04:28 PM   #4
69trk
69trk's Avatar
Re: New toy.
I can't wait to get one of those, how much did you'rs cost?
69trk is offline   Reply With Quote
Old 08-19-2008, 05:20 PM   #5
71Dragtruck
Re: New toy.
Mine was $480 Canadian up here for the dual sensor model, I've seen them on the net down there for $400 American.
Sponsored by:
Hard Candy Customs
Old 08-19-2008, 08:55 PM   #6
prostreet1967
prostreet1967's Avatar
Re: New toy.
does it have a record mode?
prostreet1967 is offline   Reply With Quote
Old 08-19-2008, 11:15 PM   #7
71Dragtruck
Re: New toy.
Yes it data logs in dual and single mode, you can also read seperate sides or average the two. It also has output to run to a dyno program or seperate gauge if you like. You can also add a RPM moduel for EFI calibration on a laptop, or output a simulated narrow band signal. If you don't have the cash for the dual you can buy the single and then upgrade with another sensor later with the F.A.S.T. unit. And no I don't work for FAST or sell them, just found them to be a good bang for the buck so to speak.
Sponsored by:
Hard Candy Customs
Old 08-19-2008, 11:32 PM   #8
bigjimzlll
bigjimzlll's Avatar
Re: New toy.
This is the one I ordered
Comp Cams #249-170608
Dual Air/Fuel Meter
Ethanol/Methanol
Will work with E85/E95
2 Sensors
$424.83
Ships
in 15-22 days
Anderson,CA
Old 08-19-2008, 11:41 PM   #9
71Dragtruck
Re: New toy.
Hey Jim what ratio do you think I shoud try to tune when I'm on the bottle? 150-180shot. Right now I'm at 12.5-13.0 on motor @WOT, was thinking 11.0-11.5?
Sponsored by:
Hard Candy Customs
Old 08-19-2008, 11:47 PM   #10
bigjimzlll
bigjimzlll's Avatar
Re: New toy.
I have no idea...I'm in the same boat
Anderson,CA
Old 08-19-2008, 11:50 PM   #11
71Dragtruck
Re: New toy.
Should check price here.
http://www.rpmoutlet.com/mt.htm
Sponsored by:
Hard Candy Customs
Old 08-19-2008, 11:56 PM   #12
71Dragtruck
Re: New toy.
FAST recomends 12-13.5 on motor WOT, low to medium 15psi boost 11.8-12.5 and high to 30psi boost 10.0-11.8. So was trying to convert that to nitrous #'s.
Sponsored by:
Hard Candy Customs
Old 08-20-2008, 01:17 AM   #13
bigjimzlll
bigjimzlll's Avatar
Re: New toy.
The ethanol one is a little more expensive. but that is a very good price
Anderson,CA
Old 08-20-2008, 01:32 AM   #14
71Dragtruck
Re: New toy.
Ya didn't see yours listed there just the one I got, posted that up for 69trk, that's a pretty good price your getting yours for, bet mine there would be even less then $399. I kinda wanted mine now so just went local and had it next day, other places up here wanted $550 for mine so wasn't as bad as it could have been.
Sponsored by:
Hard Candy Customs
