Old 08-19-2008, 10:28 AM   #1
72blazer_mud_bogger
72blazer_mud_bogger's Avatar
Beer Keg Fuel Tanks
looking to take my tank off the bottom of my blazer and run to full size beer kegs up top, trying to figure how i can avoid sloshing of the fuel inside the keg. any ideas would be great.....
72blazer_mud_bogger is offline   Reply With Quote
Old 08-19-2008, 10:58 AM   #2
vtblazer
vtblazer's Avatar
Re: Beer Keg Fuel Tanks
Foam and/or baffling are used a lot but either is going to be tough to make happen with an old beer keg, unless you have the skillz to cut one open and do the install.
Why not just go fuel cell?
vtblazer is offline   Reply With Quote
Old 08-19-2008, 02:48 PM   #3
72blazer_mud_bogger
i got a guy that can weld aluminum, i am just trying to figure out how it should be done once i get inside, what would work the best. may just add a screw on type (or something like it). this is all new to me so, and all the guys i know that go wheeling in my old area run fuel cells, just wanted something different. if i have to i will go with fuel cell, but i want to see if i can make this work first. how often do you see a 72 blazer with beer kegs for fuel tanks
Old 08-19-2008, 03:36 PM   #4
johnnywagon
Sofa King. We, Todd, Ed.
johnnywagon's Avatar
RCI sells safety foam "bricks" for use in fuel cells. They also sell universal floats/sending units but you would have to some how shield the loose foam fbricks from interfering with the float.
~John
71 Blazer One Ton
65 Chevelle Station Wagon x2
59 Belair 2 Door
71 Chevy Open Road Van RV
www.myspace.com/johnnywagon
johnnywagon is offline   Reply With Quote
Old 08-20-2008, 07:05 AM   #5
OLDCHEV4X4
OLDCHEV4X4's Avatar
The float in my fuel cell is inside a tube so that nothing interfear's with it.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 08-20-2008, 08:39 AM   #6
dammitmitchell
the pollock
dammitmitchell's Avatar
hey if you can like angle the bottom of the keg like a convex curve, or just a big dip for your pickup tube to sit in, thaty way if you ar "slohing" on low fuel you still ahve a good pick up point
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 08-20-2008, 01:02 PM   #7
Batman
Beer kegs are usually stainless, haven't seen an aluminum one. Sounds like an interesting project.
1972 GMC K1500 350 V-eight TH350 4x4.
Batman is offline   Reply With Quote
Old 08-20-2008, 01:22 PM   #8
72blazer_mud_bogger
well that makes it easier, the one i was looking at in chicago last year when i lived there where aluminum. i didnt explect it to be easy, but it will not be the most common fuel cell. thanks for the help
Old 08-20-2008, 03:12 PM   #9
jc
jc's Avatar
ive scrapped pleanty of kegs and about half where aluminium and the rest where stainless.
today i just baught a real nice stainless slitz OLD beer keg for a gas tank that is stainless.
2004 Silverado 2500HD Crewcab 4x4
2000 TOYOTA 4RUNNER
1971 CHEYENNE LWB (THE LOVE SHACK)
1967 c-10 lwb (THE FARMERS DAUGHTER)
jc is offline   Reply With Quote
Old 08-20-2008, 06:41 PM   #10
Wreckless_71
Wreckless_71's Avatar
My buddy has a keg for his fuel cell on his VW Baja Bug it's pretty sic. He has it mounted up on his rack with some KC's an axe and a shovel.
1972 K10 4" lift, 35’s, 383 stroker, 700r4, current project.
1971 C10 3"/5" static drop, 355/350. "La Bamba.” The current daily driver.
Wreckless_71 is offline   Reply With Quote
Old 08-20-2008, 08:25 PM   #11
jc
jc's Avatar
i just checked the date on the keg. its 2-71 excellant!!!!!
2000 TOYOTA 4RUNNER
Old 08-20-2008, 08:50 PM   #12
70gmcjimmy
GMCDAC
70gmcjimmy's Avatar
This is sure a subject I've never seen before!
Back in the 70s before dirt circle track racing rules began requiring actual fuel cells they generally mandated a welded 1/8" steel tank rule. Sloshing fuel was a problem when the driver would throw the car into the turns, as it could cause the car to get too loose. One way we prevented that was to fill the tank with wiffle balls. It worked real well!
If you have a large enuff access hole using the foam blocks that Johnnywagon recommended is definitely the way to go. To fit that foam into an odd shape such as a keg, an electric knife like you carve a turkey with can be used to shape it so it isn't compressed, then it will absorb and drain fuel from it much better. Don't tell the wife you used the knife, or in my case many years ago, my Mom!
I have drained many a keg thru the years and have never seen a stainless steel one! Never knew they existed. That is my education for the day!
Later---DAC
1970 GMC K5 Jimmy Custom 4X4 Mom's driver from 1971 to 2001!! Under rebuild!
1972 GMC C2500 Pickup owned since 1979 Needs a rest and refurbish!
1955 GMC 100 2nd design driven almost daily!
Rest In Peace Mom. "Dolly" 7/15/23 - 5/18/09
GMC driver for 30 years!
70gmcjimmy is offline   Reply With Quote
Old 09-16-2009, 10:06 AM   #13
T/C
T/C's Avatar
Okay bump for an old thread... I have a 1970 GMC SWB and the tank inside the cab is leaking... I got ahold of a free keg and want to do this... How big of a problem is it for a truck that is going to just be driving on the road? (With the Slosh) And if i need to do something to help with it... Do the wiffle balls not melt or anything? (Sorry if thats a dumb question but i dont know Lol) and how full would i fill it with them?
T/C is offline   Reply With Quote
Old 09-16-2009, 10:42 AM   #14
ghettoluxury
ghettoluxury's Avatar
it is no different than your current tank
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 09-16-2009, 10:44 AM   #15
cobinder
Everything is work in progress
cobinder's Avatar
Fill the keg with foam balls. They are made for motorcycles. Just keep stuffing them in there till you get teh effect you want.
Good luck with your truck!
How much?! It's just an old truck part!!
49 International on a 80 GMC 3/4ton 4x4 chassis
48 International KB-5 2 ton dump bed
04 Honda CRF "500"
09 Honda CRF450 fuel injected rocket
03 Suzuki hayabusa carbonfiber wheeled monster.
02 Ford diesel stretch van (toy hauler)
01 38' Monaco diesel pusher motorhome
cobinder is offline   Reply With Quote
Old 09-16-2009, 10:47 AM   #16
T/C
T/C's Avatar
Thanks guys.. Lol Pulled 3 gas tanks from a few parts cars my girl friends dad has and found none i could fit under the bed.. Then we found the old keg lol
Old 09-29-2009, 09:07 PM   #17
packrat42
packrat42's Avatar
T/C, Do you have any more updates on the keg gas tank? I just bought one last weekend and I was gonna do the same thing.
'72 Nova
'71 C10
'63 VW Beetle
...............................____
.................________-|___\____
..;.;;.:;:;.,;.|__(O)___|____/_(O)|
_______________________________________
packrat42 is offline   Reply With Quote
Old 09-30-2009, 08:56 AM   #18
T/C
T/C's Avatar
The deal i had fell threw... I am still trying to find something... If i find a keg first i am going to go with that but if i find a normal tank i will use it.. I will let you know when i figure out what i am doing...
The worst part is you cant buy a keg here (I am not sure about other states) But from anyone who is really allowed to be selling them if you dont have a tdc? Or something like that.. So i cant just go buy one from anywhere..
Old 09-30-2009, 11:40 AM   #19
ghettoluxury
so rent one empty it out (with the help of some friends) and forget to return it
Old 09-30-2009, 12:53 PM   #20
Batman
Technically, that's illegal. However, it does happen quite a bit. Those kegs are the property of the brewery and they cost the brewery a lot more than the deposit one leaves on them.
Old 09-30-2009, 01:30 PM   #21
T/C
T/C's Avatar
And also... I am not 21 nor are any of my friends that would think about doing that anyways
Old 01-14-2012, 07:47 PM   #22
72blazer_mud_bogger
The best place that I have found to get the kegs from is college parties. Hope that helps, I am finally getting around to getting my two kegs together and getting put in the truck. I will try to take some pics as I go for you all
Old 01-18-2012, 02:26 PM   #23
mikemileski
Maybe you can get one of those guys that build ships in bottles to make you some baffles for the inside of those kegs :-)
Mike Mileski
Tucson, AZ
mikemileski is offline   Reply With Quote
Old 01-18-2012, 05:27 PM   #24
Mxracer202
Mxracer202's Avatar
Thought about the same thing with the keg idea for my 58 willys. buying kegs here Is a pretty simple task, They sell for about $40.
but back to the sloshing, If you cant get the right foam in the keg you can also go with wiffle balls as 70gmcJimmy said Its pretty common on prerunners and desert trucks. Theres tons of "wiffle ball" threads onhttp://www.Dezertrangers.com
I think the kegs would be a pretty sweet idea,
My .02
58 Jeep willys pickup
67 K10 4x4- soon to be trail truck
TROUBLE MAKER RACING
"If you can't stand BEHIND our troops, please stand in FRONT of them."
Mxracer202 is offline   Reply With Quote
Old 01-18-2012, 10:34 PM   #25
72blazer_mud_bogger
thanks guys, I will be trying this soon.
