Old 08-19-2008, 12:02 PM   #1
65post
Vin Decode
I need some help on decoding this vin....KE104 - 1112XXX..GM OF CANADA TELLS ME THAT THIS IS NOT THE VIN #.I GOT IT OFF THE STICKER ON THE INSIDE OF THE GLOVE BOX.( VIN PLATE ON THE POST HAS GONE MISSING ).THERE IS NUMBERS ON EACH SIDE OF THE FRAME RAILS JUST BELOW THE DOORS. ARE THESE NUMBERS THE VIN OF THE TRUCK? THANKS IN ADVANCE. TERRY
65post is offline   Reply With Quote
Old 08-19-2008, 12:26 PM   #2
Re: Vin Decode
Looks like you are missing a digit. Here is a good decoder.
http://www.gmcpauls.com/67-72_chevy.htm
The numbers on the side of the frame are not your VIN. On the frame ith will be on the drivers side on top near the steering box mount or n the railk under the cab about right under the driversd door area.
You should have a VIN tag on the drivers rear door post. That is whjat the factory used for VIN placement primarily.
Old 08-19-2008, 02:34 PM   #3
65post
Re: Vin Decode
Thanks for the site.I got another question,are the gmc vin plates marked GMC MAXIMUM CVW RATING instead of CHEVROLET MAXIMUM CVW RATING ? and if so what would it be for a 1/2 ton 4x4 with 16 inch wheels ?
Old 08-19-2008, 03:24 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Vin Decode
that is a GMC VIN, not a chevy VIN.... Chevrolet of Canada won't be able to answer your Q's about it.
What year GMC is it? They don't decode the same year to year.
