Need More Vacuum For Disc Brakes
I have about 17 lbs of vac. going to the booster from the a 1 port valve from the back of the intake and about the same from a back of the carb. how can i get more vac.Im working on a 72 blazer 4x4 with a/c
Re: Need More Vacuum For Disc Brakes
What cam is in the motor? What booster do you have? Why do you think you need more vaccum?
Mike
Mike Redpath Last edited by Musclerodz; 08-19-2008 at 02:10 PM. |
i have a mild street cam size unknown i just put a delco booster on it only showing 18 lbs of vac. the pedal is still going almost to the floor after new brakes and master cylinder and booster
sharp as a marble
![]() Join Date: Jan 2007
low vacuum problems result in a very hard pedal ( no assist )
not low pedals. I would recheck adjustment at rear brakes, and then rebleed system. 17-18 inches should be enough to make that system work fine Last edited by cparman; 08-21-2008 at 07:14 AM. |
I went crazy for 2 years trying to get my 72 brakes working well. Tried the 3/4 ton booster etc. Then went back to square one--replaced wheel cylinders, calipers, shoes/pads, master cylinder--but the real issue is to bleed the front and rear brakes really well making sure to pull or push the pin in the proportioning valve when you bleed. Once I did that the right way (can't remember to push or pull the pin??)---the brakes work super--will pop you into the windshield if not belted in. My Blazer has a performance Cam with edelbrock intake etc. pushing about 16-18 inches of vacuum. Huck
Thanks For All The Info. I Will Definitely Try That.
Thanks |
