08-19-2008, 10:47 PM | #1 |
IFS crossmember, using s10 parts
I found this, looks like a good option. What do you guys think about it? http://www.stovebolt.com/ubbthreads/...338344&fpart=1
65 Chevy C10 Panel http://67-72chevytrucks.com/vboard/s....php?p=7148391 42 Chevy 3100http://67-72chevytrucks.com/vboard/s...92#post7184392 96 GMC K2500 Diesel Suburban 89 GTA Trans Am Convertible. |
08-20-2008, 01:00 AM | #2 |
Re: IFS crossmember, using s10 parts
Sounds like it might work!
My Dodge Dakota looks similar, but its Mopar not a GM!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
08-20-2008, 12:36 PM | #3 |
solidaxle: that dakota front end looks great! imho if it works i woundn't care if it was from a YUGO!
08-20-2008, 02:22 PM | #4 |
Hollister Road Co.
I've been following that thread over there for awhile and it looks like the first "NEW" attempt at an AD suspension in along time. Its built from scratch for the AD using GM parts not an MII make over.
08-20-2008, 08:08 PM | #5 |
I just checked it out and it looks pretty interesting especially if he sticks to close to his original price. The doner cars for those front end pieces are pretty plentiful and cheap around here. It looks like a guy might not have to hack up his inner fender wells to install it too.
08-20-2008, 09:34 PM | #6 |
I have a few concerns,
What is the height of the front end, it looks like the spindel centerline is is way below the bottom of the frame which raises the front end up to the stock height. Do they make 2 or 3" dropped spindles for S-10' ? The top hats look like they have just a vertical weld attaching them to the frame rail, that seems to put a lot of shear on that hat with all of the weight of the truck on the spring hat. It is nice to see some more inventions for our AD trucks, I do like the idea of a truck suspension on a truck but it must have rack & pinion that is why I went with the Dodge
08-20-2008, 10:20 PM | #7 | |
08-21-2008, 09:44 AM | #8 |
The Dakota bolt on parts are priced very low also, I have not checked into the aftermarket for spindles but he says it will sit right, he is a hot rodder.
08-21-2008, 01:39 PM | #9 |
I'll agree that it puts the ride height higher than I prefer. I have two complete MII setups out here plus both the proper GM and Ford rotors so that cuts my cost if I use Original MII suspension pieces.
My liking for the GM setup is that a guy wouldn't have to mix and match parts except the rack. No remembering what one piece or the other came from if you have a bearing go out or need pads or a rotor for the brakes. and no one off custom bushings in the suspension. I have no interest in using air bags as a primary suspension component and don't care for the "laid out" look that seems to be the big thing. Totally personal opinion and the fact that I don't want something on the truck that will cause me to be hung up in the middle of the road if it fails. I push the limits on scrub line and will stay that way. I may use bags on the rear to maintain static ride height in conjunction with the springs I run though as i don't like the looks of the truck when I get my gear loaded in the bed for a road trip. I have pretty soft springs on the back with stiff gas shocks and can't haul any kind of load without it dropping in the back. I haven't done a lot of checking around here but from what I've seen the Dakotas don't tend to make it to the local wrecking yards in any appreciable number. That and most of the Dakotas around here and most S=10's for that part are four wheel drive. Last edited by mr48chev; 08-21-2008 at 01:47 PM. |
08-21-2008, 03:17 PM | #10 |
I've been in communication with Danforth, about making a crossmember for the 55-59 Trucks, however, the last price I saw from him on the AD crossmember was around $800.00, better check with him. For that price (I have a 56) I would go with the Corvette crossmember. Just my two cents. Tom
08-22-2008, 09:49 AM | #11 | |
BTW DJM makes many of those parts for Dodge Dakotas too. |
08-22-2008, 10:33 AM | #12 |
[BTW DJM makes many of those parts for Dodge Dakotas too.[/QUOTE]
Thanks for the tip, After all these years of playing with my toys I have not learned a new language "D o d g e" I will look into DJM.
08-23-2008, 01:26 AM | #13 |
I can probably get one of the local wrecking yards to chop me off a front stub from one of the Metric cars mentined for about 100 bucks and then strip it at home while the Dakota pieces seem a bit hard to come up with in this area and will probably cost three times as much.
probably 70 percent of the Dakotas that were sold new in this area no matter what the year model were four wheel drive trucks. The same goes for the S-10 trucks. |
