Old 08-20-2008, 12:11 AM   #1
joe231
joe231's Avatar
original a/c???
check out these original "RARE" 4-5-6 a/c parts,
http://cgi.ebay.com/ebaymotors/Parts...=p4506.c0.m245
correct me if I'm wrong , some of this stuff doesn't look factory
CHEVY ONLY
Old 08-20-2008, 01:48 AM   #2
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: original a/c???
are those gm? or are they a dealer installed aftermarket?
Old 08-20-2008, 08:08 AM   #3
joe231
joe231's Avatar
Re: original a/c???
dunno, but i don't think they are "factory"
CHEVY ONLY
Old 08-20-2008, 09:28 AM   #4
LILRED66
LILRED66's Avatar
Re: original a/c???
According to all the factory/dealer literature I have collected over the years, these items are not factory, as least for the 4-5-6 Chevy trucks.
I couldn't connect on the eBay links.
LILRED66 is offline   Reply With Quote
Old 08-20-2008, 09:47 AM   #5
joe231
joe231's Avatar
Re: original a/c???
thanks for the info Tony
I changed the links, give 'em another try
CHEVY ONLY
Old 08-20-2008, 10:01 AM   #6
Chevy Fleetside
Chevy Fleetside's Avatar
Re: original a/c???
This looks like a compressor from a Ford Mustang. I remember because my mom had a 68 with A/C, and that is what i looked like. I could be wrong seeing the picture is not very good.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 08-20-2008, 01:22 PM   #7
jonzcustomshop
1961 crewcab
Re: original a/c???
If that is a ford compressor, I think they work good to convert to airride systems.
Old 08-20-2008, 01:58 PM   #8
pquick
pquick's Avatar
Re: original a/c???
Really!? that is a great idea...have you done it ar any link to one doane?
pquick is offline   Reply With Quote
Old 08-20-2008, 08:10 PM   #9
JQ-72
JQ-72's Avatar
Re: original a/c???
The vents are correct for 64-66 GMC trucks. I had a 66 panel that had the factory a/c on it. It uses the same heater box as Chevy and pull cables are mounted under the radio. The vents bolt under dash on left and right side. A friend of mine has a 66 1/2 ton with it too.
Joshua
72 Cheyenne Super swb. Factory 402/400,tach,posi,AM/FM, A/C. Adding cruise, 8-track
72 Cheyenne Super swb. 350/350 A/C, bucket seats
72 Cheyenne swb. Factory 402/400, tilt, posi, A/C
72 Cheyenne Super K-10. 350/4 spd., posi.
72 Suburban 350/350 tilt, tach, AM/FM, A/C, luggage rack
72 GMC Sierra lwb. 350/350, A/C. medium green/olive interior
JQ-72 is offline   Reply With Quote
Old 08-20-2008, 10:13 PM   #10
LILRED66
LILRED66's Avatar
Re: original a/c???
This is the factory A/C set-up on the 4-5-6 Chevy trucks. The other set-ups are aftermarket installations.
Old 08-20-2008, 11:12 PM   #11
RunninLo
3DrDwn--the 'burb not the band
RunninLo's Avatar
Re: original a/c???
the compressor is a york that was also labled as a motorcraft part and did AC duty on many 60's and 70' vehicles mostly fords and Mopar. They still make them and they make fantastic air ride compressors.
good info here:
http://www.kilbyenterprises.com/compressors.htm
Also anyone who has heard of the Oasis those are basically york compressors hooked up to a DC motor similar to those that run hydraulic pumps.
Josh
Slo and Lo that is the tempo.
'72 burb build page here:
http://67-72chevytrucks.com/vboard/s...d.php?t=259256
'89 GMC Dually crew build page coming soon.
88 4x4 crew DD
duallys past/present pics here:
http://67-72chevytrucks.com/vboard/s...46#post4001246
89 1 ton Dually rear flip kit install here:
http://67-72chevytrucks.com/vboard/s...d.php?t=354327
RunninLo is offline   Reply With Quote
Old 08-21-2008, 12:11 AM   #12
joe231
joe231's Avatar
Re: original a/c???
hey scotts62, you still have that link to the homebuilt oasis I sent you?
i have it around here somewhere...............
CHEVY ONLY
Old 08-21-2008, 12:24 AM   #13
JQ-72
JQ-72's Avatar
Re: original a/c???
Here's a few pictures of the panel I had. Pics are not real good - 5 years ago and with a not-so-good camera!
JQ
Old 08-21-2008, 12:37 AM   #14
joe231
joe231's Avatar
Re: original a/c???
so the difference if Chevy and GMC
CHEVY ONLY
Old 08-21-2008, 10:30 AM   #15
LILRED66
LILRED66's Avatar
Re: original a/c???
That set-up was not available on the Chevy trucks.
Old 08-21-2008, 01:58 PM   #16
83burban
Re: original a/c???
Factory option versus Dealer option maybe?
83burban is offline   Reply With Quote
Old 08-21-2008, 03:15 PM   #17
joe231
joe231's Avatar
Re: original a/c???
I understand , but was it available on GMCs
obviously the Chevy a/c vents will not work with the GMC dashes, so something had to be different??
CHEVY ONLY
Old 08-21-2008, 04:46 PM   #18
JQ-72
JQ-72's Avatar
Re: original a/c???
The photo LILRED66 shows if factory A/C for Chevys. The one I posted is factory A/C for GMC. The dealer add-on units all hung under the dash, like cars. GMC has a totally different dash than Chevy, hence the different A/C set ups.
JQ
Old 08-21-2008, 04:49 PM   #19
joe231
joe231's Avatar
Re: original a/c???
JQ
that was my point exactly
CHEVY ONLY
