Loving the Jimmster
Altenator Bracket for 1967 283 Sb chevy
Ok heres the story, I have a 1976 chevy with a 283, from the numbers it is not original. I am playing around with it add somethings, i have added a new manifold and 4 barrel, the old manifold had mounting holes for the altenator, the new one does not. I also do not have mounting holes in my heads. I have purchased several new brakets and none of them seem to line up? It is currently on the drivers side as i want to add A/C soon.
So How do i tell if i have a long/short water pump? and does anyone have a picture of the lower bracket? thanks |
member #16
![]() Join Date: Dec 1999
Re: Altenator Bracket for 1967 283 Sb chevy
Here you are. Your brackets will depend on the water pump you have.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ Last edited by john; 08-20-2008 at 07:12 PM. |
Loving the Jimmster
Nice!!! I am sure it is a short, do we have any idea where the lower bracket bolted on?
Loving the Jimmster
Re: Altenator Bracket for 1967 283 Sb chevy(added Pics)
Ok guys and gals, here are some pics of my altenator brackets, the top one is good to go ih ave several different ones but the bottom is got to be replaced, the PO made some sort of bracket, although i cleaned it up and repainted it for now it is just not what i want. If you have any pics of what i nedd please post them so i can see what to buy.
thanks |
![]() Join Date: Aug 2004
The lower bracket was either part of the exhaust manifold, or bolted to the #1 cyl exhaust manifold bolts. There's a lower mount available out there for header usage, I bet it would work for you with some fitting adjustment. I think it's these 2 pieces...
http://www.jegs.com/i/Hooker/520/10927/10002/-1/744716|11063 and http://www.jegs.com/i/Hooker/520/10928/10002/-1/744716|11063
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
![]() Join Date: Sep 2005
hey mine is set up with an l bracket ont he intake which the upper bracket bolts too my low alt bolt bolts right into the manfiold.
i added some pictures of my top one the best picturtes i had
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube Last edited by truckdude239; 08-23-2008 at 08:11 PM. |
Fabricate till you "puke"
I cant help with pics, but the 67 had a bracket that bolted to the end of the ex manifold , to mount the alternator.....68 -72 had the bracket mounted to the head, but the earley heads did not have the bolt bosses in the heads. I does look like you have the short waterpump.....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Loving the Jimmster
clay that is what i have will one of them, that is what i think i need but i have know idea where it goes? Does the bracket part mount the the exhaust manifold then the alternator bracket hook to it??/ hope that made sense.
Through the 283/327 engine run the driver side exhaust manifold was a mounting point for the alternator,not the head.With early heads you need to either use original-style manifolds,drill & tap head/use washers to use later alt. bracket ,or use mount made for headers.The upper arm is longer to reach back to water pump mounting bolt.
