Old 08-20-2008, 08:11 PM   #1
spr85gmc
spr85gmc's Avatar
converting to floor shifter
currently i have a column shifter on a 3 speed 350 tranny i want to convert it to the floor to have a more hot rod look kinda like LOU has on his build thread.. the problem is i cant find any one who just sells the linkage for the tranmission any of you guys know where i can find one ..please help me out with this one in one of the mod i really really want to do but i cant find the one part i need and i already mad my 35 inch longf shiftr out of pure bordeom..
spr85gmc is offline   Reply With Quote
Old 08-20-2008, 08:38 PM   #2
S10Fan
Old Heap Driver
Re: converting to floor shifter
There are several on eBay, just make sure you buy one that fits your application. Also, if you've never performed this mod, get someone that has to give you a hand. Otherwise your truck will be parked and you'll be ready to damage some property.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 08-20-2008, 09:14 PM   #3
spr85gmc
spr85gmc's Avatar
what do i have to look out for any tips i looked on ebay earlier this week no luck unless i just have bad luck withthe search button..
Old 08-21-2008, 05:13 AM   #4
S10Fan
Old Heap Driver
http://motors.shop.ebay.com/items/__...000QQ_fromZR40
If the link doesn't work I typed "3-speed shifter" in the search box.
Bryan
Old 08-21-2008, 05:25 AM   #5
Mr79C10
It Is What It Is,,,,
Mr79C10's Avatar
Mine was converted about 4 years ago. I bought the HURST 3sp shifter, Works like a charm. Ive since changed the shifter handle to a welded links of chain for a shifter
*79 C10 Short Box ST8 6 bang'r *
*Lowered w/ 3" Control arms, 2" Lower Coils and 4" shackles and hangers W/ FLIP KIT
*__--__*
79 C-10 project
.........................__
..............._____ l __\___
..............|_(O)_ |___(O) ]
FAQ INDEX Thread
The Kulture
My Rat Den
Mr79C10 is offline   Reply With Quote
Old 08-21-2008, 09:16 AM   #6
85X3
I'm converting to a floor shifter also. I want to use a Lokar shifter. I will keep the transmission to column linkage in place, but will use a lower bowl from a Monte SS steering column. This will allow the indicator to be operational, and prevent start-up in gear.
I also live in MI and used the same LCA's you have on your truck. My truck looks just like yours, only different.
Good luck with your linkage quest.
85X3 is offline   Reply With Quote
Old 08-21-2008, 12:49 PM   #7
Hazieview
Building Dreams out of Dimes!
Hey I dont know if this helps but my B&M shifter just works off a of a cable linkage. It's a lot easier to deal with considering you can pretty much mount your shifter any where as long as the cable is long enough.
Hazieview is offline   Reply With Quote
Old 08-21-2008, 02:29 PM   #8
spr85gmc
spr85gmc's Avatar
i have heard bad thinks about cable shifters
Old 08-21-2008, 07:47 PM   #9
sqrbdy
sqrbdy's Avatar
What kind of problems have you heard that people with cable shifters are having. I currently have a Hurst Pro-matic in my truck and have never had a problem with it. I will be changing back to a column shifter but it has absolutely nothing to do with the performance of a cable shifter.
Ain't Nobody Like a Square Body
sqrbdy myspace
sqrbdy is offline   Reply With Quote
Old 08-21-2008, 07:54 PM   #10
S10Fan
Old Heap Driver
I LOVE cable shifters! You don't want to kink the cable, no tight bends etc, other than that it should be trouble free.
My comments above were directed towards someone installing a manual shifter, 3 speed, 4 speed etc.
Bryan
Old 08-21-2008, 08:06 PM   #11
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
i had a hurst shifter years ago and i bought the linkage with it.. that was the best shifter ive ever had for a manual... much better thant he three on the trees from any manufacturer which always bind up
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 08-21-2008, 08:20 PM   #12
S10Fan
Old Heap Driver
I bought a cheap Mr Gasket shifter on eBay, works just fine. Of course I customized the handle a little.
Bryan
Old 08-28-2008, 02:24 PM   #13
Pyrotechnic
Pyrotechnic's Avatar
Nice !
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 08-28-2008, 02:32 PM   #14
bigblock73
yeller
bigblock73's Avatar
As someone already said, keep the cable kink free and you will not have any issues. In other words, follow their instructions and you will be fine.
bigblock73 is offline   Reply With Quote
Old 08-28-2008, 08:58 PM   #15
spr85gmc
spr85gmc's Avatar
this is the look i want but maybe a little shorter its standard tranny though.. i was thinking about the B&M unimatic shifter and mod it a lil bit..
Old 08-29-2008, 05:16 AM   #16
S10Fan
Old Heap Driver
Keep in mind, most floor mounted automatic shifters have some sort of reverse lockout or “park” trigger/lockout lever. Either of those would be cumbersome to use with an extended length handle. I had a very basic floor shifter, again a Mr Gasket brand, in another vehicle that would have been suitable for this type of application. The shifter had no type of lockouts, bolted to the floor, and was connected to the transmission with a lever, no cable.
Bryan
