Old 08-20-2008, 08:56 PM   #1
Jcentsr6
Junior Member
Jcentsr6's Avatar
I need to raise the Bed floor....
Who can help. Any info/pics will help.
I have searched and there is not alot of info out there and I know you guys are doing it.
I have asked before...(no replies as of yet) but the time has come to do it and I dont want to trust just anyone around here to do it without pics and some help from you guys to go with it.
I am dead set on raising the floor....due to wanting to keep the stock look when walking by (other than all the custom work performed lol) and I dont really want to cut a hole in the center of the bed. Thanks for your time....and I will post pics as the project moves forward.
going to sell this one...looking for a SWB project next.
Jcentsr6 is offline   Reply With Quote
Old 08-20-2008, 10:10 PM   #2
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
Re: I need to raise the Bed floor....
i'm also planning to do this, this winter. gonna raise it so that the tops of the wheel wells hit the bottom of the middle stake hole.
i was planning on just fabbing up some angle brackets, mounting them to the inner bedside, then bolting the floor down to those. for the back, i was planning to step the floor down so it got back to factory height just before the tailgate.
curious to hear what other peeps have done.
IvelDesigns is offline   Reply With Quote
Old 08-20-2008, 10:13 PM   #3
Jcentsr6
Junior Member
Jcentsr6's Avatar
I love your project so far...Great job. I plan on raising the floor to the same level as you......I remember seeing a pic of this somewhere. As far as the bed striping the floor down.....do you mean like a 45deg angle?
Old 08-20-2008, 10:37 PM   #4
IvelDesigns
thanks man.
i believe is was rockcrwln that did it. if it's the one i'm thinking of, he also widened the wheel wells to fit some big ol' fatties under it too.
Old 08-21-2008, 03:33 PM   #5
Jcentsr6
Junior Member
Jcentsr6's Avatar
anyone? I know there are some experts on here. (even if you just post pics of others...I dont care.)
Old 08-21-2008, 04:40 PM   #6
lowriden58
lowriden58's Avatar
Well this isnt a chevy... but this is my ranger im currently workin on, i raised the floor 10"s and sectioned the wheel tubs 2" so they keep the factory look.
71 cheyenne lwb 300rwhp
best 1/4 time so far 12.8 @103
http://i195.photobucket.com/albums/z...en58/001-2.jpg
lowriden58 is offline   Reply With Quote
Old 08-21-2008, 04:52 PM   #7
Longhorn321
Size Matters
Longhorn321's Avatar
OK fellas, enlighten me. Why would you want to raise the bed floor like that? I am guessing it is for clearance for something underneath or storage underneath. Curiosity is killin me tho. TELL ME!!
"Reading the owners manual is only for quitters." Jason Harper, Bloomberg News.
...WOOOO HOOOO!!!!
Longhorn321 is offline   Reply With Quote
Old 08-21-2008, 04:54 PM   #8
Jcentsr6
Junior Member
Jcentsr6's Avatar
To make room for frame mods....To lower vehicle without hitting the Rear Diff pumkin on bottom of bed floor.
Old 08-21-2008, 04:59 PM   #9
lowriden58
lowriden58's Avatar
yup i raised it 10" because i backhalved the frame and the frame is 7 1/2" above the factory frame, im also doing a 2 1/2" bodydrop so thats what makes it 10"
im also hiding everything under the bed, air tank/compressors and fuel cell
Old 08-21-2008, 05:01 PM   #10
Jcentsr6
Junior Member
Jcentsr6's Avatar
I dont need to raise the bed that high....but want to raise it to the same level as Ivel said before. Thank for the pics...keep em coming guys.
Old 08-22-2008, 09:25 AM   #11
Longhorn321
Size Matters
OK...I see now. I could have guessed that but this is what confused me
...WOOOO HOOOO!!!!
Old 08-27-2008, 03:32 AM   #12
umwtnt
umwtnt's Avatar
I wanted to raise my bed floor 7 inches. The stock crossmembers under the floor are 3 inches so I needed to come up with a total of 10 inches. I purchased some 5 X 2 tubing and some 3/4 X 3/4 angle iron. I measured up from the original 7 inches and mounted the angle iron with self tapping screws and vise grips. I cut one piece of 5 X 2 tubing to fit the width of the bed and two small pieces at 6 inches. The rear crossmember stayed at the original mounting point. The pictures should be explain the rest of the procedure, hopefully, if not let me know. I have not had time to finish the procedure. I used self tapping screws instead of welding to set up the bed in case I needed to make adjustments.
The more I learn, the more I find out I don't know.
69 Chevy SWB w/67 front end
4 wheel discs
468 BB 700R4
Bagged
Coming around slowly
umwtnt is offline   Reply With Quote
Old 08-27-2008, 10:11 AM   #13
abadsvt
abadsvt's Avatar
Well here is how i am doing mine. I am planning on using a wood as the bed floor and since my cantilever sticks up above the floor the center section is gong to be left open. I am also going to fab up custom bed strips to hold the wood down. What i recommend is that you put an x-bracing on the tops of the bed to keep the bed square (like the pic below) first before removing the floor. I don't have much experience using the stock stuff either wood or metal floor so hopefully someone else will chime in. Sorry i couldn't be much more of a help. Let me know if you have any questions.
Josh
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
Old 08-27-2008, 11:04 AM   #14
66chevy PROSTREET
SOLD
66chevy PROSTREET's Avatar
Location: Poorest state in America(Breaux Bridge,Louisiana)
this is with the wood floor i used to have, and what i have now
1966 CHEVY FLEETSIDE
SOLD 11-29-9
TRUCK THREAD- http://http://67-72chevytrucks.com/vboard/showthread.php?t=301368&page=2
66chevy PROSTREET is offline   Reply With Quote
Old 08-27-2008, 11:46 AM   #15
LooseCannon
I plan to make this modification as well and have collected the following 2 pics.
The first one was done by Rokcrln and the second by 7T7,
LooseCannon is offline   Reply With Quote
Old 08-27-2008, 05:54 PM   #16
see ten
WTB this ad
see ten's Avatar
Shot this in Daytona.
see ten is offline   Reply With Quote
Old 08-27-2008, 06:31 PM   #17
Riveted1
Tasty Cakes!
Riveted1's Avatar
They both look good! I can't decide which one I like better, although I think your current choice goes better w/the design of the rest of the truck. So how did you set everything up under the bed floor? I'm thinking about doing this to my truck too, so the more ideas I get, the better!
I'm a little and a lot
Ground beef: A cow with no legs.
'66 Chevy SWB "Penny"
'67 Chevy Big Window SWB- aka "Pearl"
'72 Burb- "Betty" "It's not a hearse dammit"
'99 Chevy Ext. cab Silverado
Riveted1 is offline   Reply With Quote
Old 08-27-2008, 08:52 PM   #18
Jcentsr6
Junior Member
Jcentsr6's Avatar
Great stuff guys! Keep them going. I would like this to help others as well. I think this is a clean way to mod the beds. Makes me feel better about cutting something nice up...when the end result looks as good as these. No one likes a classic vehicle cut to pieces. Thanks everyone looks good.
Old 08-27-2008, 10:03 PM   #19
see ten
WTB this ad
see ten's Avatar
No one likes a classic vehicle cut to pieces. .
Sure they do! Gambino Customs even sells shirts that read "Chopping up cars is not a crime".
Old 08-27-2008, 10:54 PM   #20
66chevy PROSTREET
SOLD
this is how i had it first set for the wood. angle iron bolted to the bedsides with runners across. For the sheet metal, i raised the floor even higher to clear the hoosiers i went with, and just bolted the frame higher ,then recessed the fasteners into the sheet metal then had the bed sprayed
SOLD 11-29-9
