Old 08-20-2008, 08:57 PM   #1
coggonobrien
please help me decode my big block
supposed to be out of a 69 caprice, I haven't pulled the pan yet but here's what i've got:
passenger cylinder head from rear to front:
19/8
M Truck
GM4T
This one is tough to read but looks like 3933148
Intake manifold, 4 barrel cast
K16
This one is tough to read but looks like 3883848
GM1
T
Block
3955272
coggonobrien is offline   Reply With Quote
Old 08-20-2008, 09:23 PM   #2
red69ss
Burnouts are therapeutic
red69ss's Avatar
Re: please help me decode my big block
1969 396 go to nastyz28.com to run your #'s ,search for nastyz28 engine decoding
1969 CHEVELLE SS
1972 C10 ALMOST DAILY DRIVER
1968 C10 RUSTBUCKET (MISSION IMPOSSIBLE)
1972 PONTIAC LEMANS CONVERTIBLE (WIFE'S CAR)
"My wife and I were happy for twenty years. Then we met." - Rodney Dangerfield
"The difference between genius and stupidity is that genius has its limits." - Einstein
red69ss is offline   Reply With Quote
Old 08-20-2008, 11:31 PM   #3
72 CustomCamper
huh ???
72 CustomCamper's Avatar
The block numbers come back as 3955272....396.......69......2 or 4 bolt
The cylinder head number come back as 3933148....69-84...oval...OPEN...'69 396/265hp, 366T, 427T, 112cc chamber
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 08-21-2008, 06:05 AM   #4
coggonobrien
performance wise are the heads going to be worth using?
Old 08-22-2008, 02:20 PM   #5
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
I have a set of 148 heads and they seemed to be great heads - not a 781 but really nice for a street motor
Most folks will bad mouth them since they say Truck -
They are not peanut port heads by any stretch
I say use em
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 08-25-2008, 03:51 PM   #6
70rs/ss
70rs/ss's Avatar
112cc is about as small as you can get without using a closed chamber 98cc head or getting a set of GENIV Vortec 100cc's. All of that means you can get a better compression ratio without a pop-up or at least a smaller pop-up which saves some $$$. Oval ports without peanut ports are all good heads. Heck, peanuts work great if using it to pull (like as in a truck being used as a truck) since under 4500-5000 they produce great velocity and that helps power down low. If for a hot rod, then no, cause they tend to fall flat on their face at 4500ish rpm. Use them, they are as good as any early BBC casting, bigger valves, bowl blend, back cutting the valves, etc are all little tricks to get more out of them and shouldn't cost too much, or do it yourself, lots of books/videos out there for help.
70rs/ss is offline   Reply With Quote
Old 08-25-2008, 04:38 PM   #7
coggonobrien
can someone post a pic of a peanut port heads? just wanna see what they look like. thanks
Old 08-26-2008, 06:10 PM   #8
70rs/ss
70rs/ss's Avatar
Here is the best I could find, the intake ports are the small ports (peanut) the exhaust are the same as any other oval port head. Basically two figers would have a hard time fitting into them.
Old 08-26-2008, 07:55 PM   #9
joeys66pickup
Dr. Frankenstein
joeys66pickup's Avatar
are all BBC heads with PASS cast into them Peanut Ports?
I Wanna Go Fast!!
joeys66pickup is offline   Reply With Quote
Old 08-27-2008, 02:02 PM   #10
70rs/ss
70rs/ss's Avatar
Nope, pass is a foundry code I think. Most BBC have hi perf cast into them as well, no biggy and not any indication of what it is.
BTW if this is all 69 stuff (heads should have a casting date in them as well, usually looks like this: A 12 9, not that exact number but a letter, two numbers, then one, the letter is a month code A=Jan, 2+Feb, etc, then the two middle numbers are the day cast and the last number is the year so a 9 would be 1969. If 69 then not peanut ports, since they didn't come around till late 80's aerly 90's. they are good heads, just buy a pop-up piston to bump comp to about 9:1 and you'll be golden.
