Old 08-21-2008, 12:45 AM   #1
sweet70beast
sweet70beast's Avatar
Van tilt columns
These things are all over ebay for cheaper than real truck ones. My question is how do you get the thing to bolt up to the steering box? I know that the output shaft on the bottom of a van tilt is bigger than on a truck, so what are you supposed to put on the bottom of these to make them bolt up?
1970 Nova 327/T5 (my 1st car)
1971 K-20 350/350/205 (winter DD)
1953 GMC Suburban
1968 Chevy Bel Air
1976 Chev C-10
1972 Skylark (suncoupe)
1 of 3943 made
sweet70beast is offline   Reply With Quote
Old 08-21-2008, 01:14 AM   #2
Arad68
Trucks N Tranzams
Arad68's Avatar
Re: Van tilt columns
Check out these links to the truck tech FAQ. They will show you the way.
http://67-72chevytrucks.com/vboard/s....php?p=1818810
http://67-72chevytrucks.com/vboard/s...d.php?t=133937
http://67-72chevytrucks.com/vboard/s...d.php?t=302488
Don
'68 Chevy LB 383 TH400/GV/373 posi
'56 Chevy 4WD SWB
'64 Chevy short stepside
'79 Trans Am 455/TH2004R/12blt/4whldisc
95 Kia (Wifes car)
2002 S-10 extended cab pickup
"God punishes small sins immediately"
Arad68 is offline   Reply With Quote
Old 08-21-2008, 07:29 AM   #3
70GMCer
70GMCer's Avatar
Easy install.......
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 08-21-2008, 11:08 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I've installed a bunch of these... never had an issue with size.
Shorten the intermidiate shaft... that's the only real mod needed.
Old 08-21-2008, 12:35 PM   #5
smokekiki
Mike
smokekiki's Avatar
I am getting ready to pull the van tilt in my suburban out to do some work on it. The head is sloppy and has quite a bit of movement. For any one interested here is a link to the van tilt manual.
HTML Code:
http://www.selectric.org/manuals/column/index.html
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 08-22-2008, 09:04 AM   #6
Huck
Huck's Avatar
Shorten intermediate shaft, reposition the neutral safety switch, purchase a harness conversion, replace the turn-tilt levers, the hazard button and the shift lever and no one will know the difference from the cab!
Huck is offline   Reply With Quote
Old 08-22-2008, 09:37 AM   #7
WIDESIDE72
WIDESIDE72's Avatar
I just picked up a van tilt on Screwbay For $100. I just realized that it was sold w/o the intermediate shaft? Can I use the intermediate shaft from my non tilt column. BTW, some of the the links used to describe the wiring and neutral safety relocate are no longer valid. I could not fond anything in the FAQ section... Another BTW, I go tan email that after Oct., Screwbay will no longer allow money orders or personal chacks as payment. Electronic payment only. Just a coincidence that they own Paypal now?
WIDESIDE72 is offline   Reply With Quote
Old 08-22-2008, 10:12 AM   #8
WIDESIDE72
WIDESIDE72's Avatar
I was scouring the local yards the last few weeks in search of the ever elusive VAN tilt with key on the dash. I have come across ALOT of the later model vans with the key on the column.Has anyone here transplanted one of these into a 67-72 truck? I was thinking if someone was going to go custom anyway, why not add some security by adding a locking column to your truck and filling the old keyhole in the dash?
Old 08-23-2008, 03:00 AM   #9
sweet70beast
On the links posted by Arad68 there is a post with a link to http://www.customclassictrucks.com/t...c10/index.html
and in the article I noticed they used an intermedate shaft from a 73-87 truck which answered that question for me.
I to would like to know about the neutral safty switch modification, I hadn't heard of it before.
1953 GMC Suburban
1968 Chevy Bel Air
1976 Chev C-10
1 of 3943 made
Old 08-23-2008, 08:09 AM   #10
Huck
Huck's Avatar
Early Chev van tilt columns are longer & the placement of their neutral safety switch binds off on the column support bracing on a truck thus you need to reposition this switch. Cut outer column with dremel -weld in a little tab--and re attach for clearnace.
The intermediate shaft is virtually identical between tilt and not tilt but you will need to shorten it for a van tilt. Drill out 2 plastic plugs (sand flat area of shaft to find them) then shorten the shaft by pressing it together.
Most van tilts have a flat connector for the wiring harness while trucks have a 1/2 moon connector. GM offers a conversion harness for this for about $12.
Van tilts typically sell for $100-200. while original truck tilts go for $250.-350. It takes about an hour to convert a van tilt to work identical to a truck tilt.
Most Van columns have a smaller steering wheel, rubber tipped levers, and many have cruse turn signal levers which can be wired into a theft diterrent (ie push the button for start!) Huck
Old 10-21-2008, 08:45 PM   #11
Ackattack
Ackattack's Avatar
bringing this one back up
I'm working on modifying my van tilt column per the FAQ. I cut the outer housing, and then the inner shifting tube. I got a new neutral safety switch and it has a "slice" in it, where it looks like a tab would go from the inner shifting tube. This part doesn't sit down in the inner shifting tube. You mention something about welding in a tab. Am i missing something here?
BTW I must have gotten an earlier one, cause it has the half moon connector....scored it for $75 at the bone yard.
Ackattack is offline   Reply With Quote
Old 01-31-2023, 11:47 AM   #12
Auctioneerhere
What spline count are the van columns? that never seems to get mentioned & for me it would be helpful.
Auctioneerhere is offline   Reply With Quote
Old 01-31-2023, 03:49 PM   #13
Southcity
Southcity's Avatar
I recently had board member 70shortfleet convert a 70's automatic van tilt to manual for my 66 K10 Suburban. He does outstanding work and can customize them any way you like. I cut the original manual steering shaft to desired length, then used a Borg steering coupler (welded to original steering shaft) to join the two together. I have found that in most cases, the spline on the van tilts is 3/4 in. 36-Spline.
https://www.summitracing.com/parts/BRG-313400
66 GMC Suburban Custom
66 Chevy K10 Suburban
Southcity is offline   Reply With Quote
