Old 08-21-2008, 02:58 AM   #1
slimneverdies
slimneverdies's Avatar
Mix and Match
Guys I have a question about these AD trucks. I bought a 53 and now its time for a parts truck. I was wondering if a 50 chevy could use the same parts. I have access to a 50 chevy and all I want to keep of the GMC is the cab. I cant fix the 50 chevy because it doesnt have a title or vin #'s. So cant I change everything except the cab on the 53 GMC and just put on a GMC grill? Besides I think the GMC's are more rare to see.
Oh yeah they are both 1/2 ton shortboxes.
Long live SLIM
At least try to buy American
slimneverdies is offline   Reply With Quote
Old 08-21-2008, 08:42 AM   #2
weldvair@embarqmail.
Re: Mix and Match
Yep!
weldvair@embarqmail. is offline   Reply With Quote
Old 08-22-2008, 10:42 AM   #3
solidaxel
solidaxel's Avatar
Re: Mix and Match
Keep the cab, chassis and title!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 08-22-2008, 01:35 PM   #4
slimneverdies
Re: Mix and Match
Thanks. Now can someone direct me on this site to "how to disassemble" one of these trucks.
Long live SLIM
Old 08-22-2008, 01:56 PM   #5
robin58
Re: Mix and Match
Your best bet would be to buy the Factory Assembly Manual carried by most of the vendors.
robin58 is offline   Reply With Quote
Old 08-22-2008, 02:06 PM   #6
slimneverdies
Re: Mix and Match
Ive look through bookstores and auto parts stores and cant find these books? Where do you suggest? Im ready to start on my first project
Long live SLIM
Old 08-22-2008, 02:17 PM   #7
Re: Mix and Match
Do a search for Chevy Duty(they are called buy another name now,but a search will get them). They have them.
Don Meyer
Old 08-22-2008, 03:23 PM   #8
solidaxel
solidaxel's Avatar
Re: Mix and Match
Start with the parts truck,dis assemble it first that should give you enough experience. A basic wrench kit should be all you need along with a lot of ambition!!
LS 3 4L70E
Old 08-22-2008, 05:07 PM   #9
BigBlocksRule
Re: Mix and Match
You'll probably need a cheap angle grinder from Harbor Freight, a couple of good pairs of vice grips and maybe even a blue-tipped Crescent Wrench (torch). I can guarantee there are a lot of bolts that are rusted solid and it's much easier to go ahead and bust 'em rather than trying to work 'em loose - as long as there's a nut on the other side and it's not threaded into a boss or other part.
BigBlocksRule is offline   Reply With Quote
Old 08-22-2008, 08:02 PM   #10
slimneverdies
Re: Mix and Match
Thanks guys. Ive bought a 60 gallon air compressor tank, all sorts of little connections, and a small tool set. My buddy let me borrow his torch. Ive never done any work on my cars and this should be interesting. Though Im not a spring chicken Ive been around this type of stuff for years. Ive probably been through 15 cars in my lifetime and most of them customized by someone else.
Long live SLIM
Old 08-22-2008, 09:04 PM   #11
54 jimmy
54 jimmy's Avatar
Talking Re: Mix and Match
lmc truck has the factory assembly manuals. the part# is 30-0400 for the 47-55 ad trucks it costs $29.95 their # is 1-800-562-8783 or the web site is LMCTRUCK.com hope this helps you out. when i took mine apart i didn't need a torch just alot of loose juice aka pb blaster. to help with assembly later get lots of different size zip lock bags and lable them. this helps with the final assembly later,and so you don't mix the parts up since you have two trucks that you are taking apart.
There is nothing you can't fix with a BFH or a FIRE WRENCH.
1997 chevy k1500 ext cab z71 (daily driver) sold
1996 chevy k1500 reg cab 4x4(daily driver)totaled
2008jeep patriot (wife's daily driver
2008 chevy 1500 ext cab 4x4 sold
2011 chevy 1500 crew cab ltz (daily driver)
1996 chevy 1500 reg cab 4x4 project sold
2006 pontiac grand prix gxp (daily work commuter)
54 jimmy is offline   Reply With Quote
Old 08-22-2008, 09:19 PM   #12
slimneverdies
Re: Mix and Match
is it me or are the 53 GMC hood and grill dimensions different? Im just looking at them in the rain an cant really tell.
Long live SLIM
Old 08-22-2008, 11:00 PM   #13
54 jimmy
54 jimmy's Avatar
Re: Mix and Match
the front clips on the chevy and gmc are different. even the rad support on the frames are different. found that out the hard way.
Old 08-23-2008, 01:07 AM   #14
mr48chev
mr48chev's Avatar
Re: Mix and Match
The assembly manual is a must have even though it is right at 30.00 it will save you a lot of grief.
I'd suggest investing in a couple of cans of PB Blaster, that sprayed on rusty nuts and bolts will save a lot of energy and frustration.
Outside of the original engines the biggest differences in these trucks are the front cross members that support the radiator support, the radiator and radiator support them selves and the grill assembly. There are also some differences in the dashes.
the other big difference that I have seen is that most GMC half tons are long beds while the Chev half tons are short beds.
It wouldn't be that hard to shorten the longbed frame and a guy could even step it a bit in the process to get the back of the truck lower.
I've got a bare GMC frame out here beside the shed if you need photos to look at for comparison. I'll have the nose off my 48 Chev in a few days and the engine out to be able to take photos of that too if needed although there are several photos of bare Chevy AD series frames on here already.
Old 08-23-2008, 10:28 AM   #15
floridasteve
floridasteve's Avatar
Re: Mix and Match
You also need to order the screwdriver set from one of the companies. The bolts used have the weird figure 8 looking heads on them. Some may twist off the others you will have to influence with whatever method you deceide on (torch, grinder or other). I think the best advise was learn from the disassembly of the first. It is pretty straight forward and not real complicated. Good Luck and the people here are always helpful
One day I am going to finish this project!
1949 Chevy 1/2 ton
floridasteve is offline   Reply With Quote
Old 08-23-2008, 11:04 AM   #16
lazerus
Re: Mix and Match
those screws are clutch head screws if there is a napa near you they should carry the screw driver you need
lazerus is offline   Reply With Quote
Old 08-23-2008, 12:53 PM   #17
slimneverdies
Re: Mix and Match
Thanks fellas. Im acutally in NAPA as I was reading this post
Long live SLIM
