Old 08-21-2008, 06:42 PM   #1
beeftip
beeftip's Avatar
1970 CST-10 Boat Towing
To tow or not to tow...
3 speed manual
Manual Disc Brakes
Coil rear springs
No idea what the final drive ratio is
350 V8
Hitch is attached to frame and appears beefy
I have no idea what shape the suspension and bushings are "really" in. I know I can load the bed with a 1/2 ton of crap and everything handles fine.
Willing to upgrade to Power Disc on the front.
I walked into a nice deal where I'm trading my web development services for a boat. The truck is just sitting around anyway, maybe I can use it to tow the boat. I'm as green as it gets when it comes to trailering a boat regardless of the tow vehicle.
Boat and trailer weight will not exceed 3,000 pounds. Trailer will have surge brakes.
The biggest question is can I safely stop with power discs on the front? Next biggest question is getting up hills. What if I just keep the drums and get a power booster?
I appreciate all honest opinions on this. If I'm a moron for thinking of attempting it, then say so. Lord knows we don't need anymore idiots on the road. I've got no problem selling the truck in order to get a more suitable tow vehicle.
1970 Chevy CST-10
3 speed manual (3 on the tree, baby! Woo Hoo!)
GM Goodwrench rebuilt crate motor
Manual Drum Brakes
Permanently foggy windshield
Weak Wiper Motor
Squeaky Clutch and Brake Pedal
Really Cool Green Paint
It's for sale!
beeftip is offline   Reply With Quote
Old 08-21-2008, 06:51 PM   #2
Cyclone44
Step Brother
Cyclone44's Avatar
Re: 1970 CST-10 Boat Towing
I tow a 28 foot pontoon with my 69 and it's a 6 cyl. 3 spd. manual...No problems at all...
Cyclone44 is offline   Reply With Quote
Old 08-21-2008, 06:53 PM   #3
Jtrux
I'm a poor spectator
Jtrux's Avatar
3 speed manual
Manual Disc Brakes
Coil rear springs
350 V8
My first truck was a 77 F100, 3 on the tree, 303 with 3.00 rear end and it pulled my friends boat all day without any problems. Give yourself more room for stopping and you'll be fine, that's what it was made to do anyways.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 08-21-2008, 07:03 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
if original, and not optioned otherwise (listed on the SPID) then you should have a 3.73 rear gear if memory serves.
My opinion... hook up to it, and go out and learn to drive it. You have brakes on the trailer, if they work, then stopping it should be just as easy as stopping without it.
3000 pounds is nothing. You'll feel it back there... but the truck can do it no problem.
Rear suspention condition, it'll let you know if this is an issue. drive it slow at first, around the neighborhood, maybe down a main road. If it sways a lot, then you'll know to address the issue before gettin on the freeway.
Just aproach it with common sence, and you should be fine.
Old 08-21-2008, 08:39 PM   #5
haysonj
haysonj's Avatar
Just make sure your surge brakes are adjusted right or they will be of no help. My boat weighs over 4000 and I added electric brakes on the other axle. Now I can stop the truck with the trailers brakes.
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 08-21-2008, 09:14 PM   #6
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Adding power brakes shouldn't do anything but decrease pedal effort,if the brakes are good anyway.Disc's might be a good plan if you do much towing or driving in an urban high traffic area.When you start learning to tow drive around in some areas without much traffic and then take it to a parking lot that is empty.Try backing up and turning the trailer.The easiest way to learn to back a trailer is to hold the bottom of the wheel and turn it the way you want the trailer to go.Go easy and watch your front fenders as well as the towed vehicle.Don't try to turn too tight.Find a ramp somewhere and learn to stop on the ramp,then take off.When you can do that without the truck rolling back you should practice a bit more before backing a boat into the water.
The oly way to learn to tow any kind of trailer is to just do it but you should always pick ayour poison.The above will not teach you to tow but will help you get started.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 08-22-2008, 09:00 AM   #7
Huck
Huck's Avatar
Should be fine but don't expect too much from the surge brakes. Many states have outlawed the use of surge brakes and require electric as they work a whole lot better.
Huck is offline   Reply With Quote
Old 08-22-2008, 09:15 AM   #8
steelhorse
steelhorse's Avatar
Should be fine.If you want a cheep brake upgrade find a 73-87 parts truck and switch out the front suspension with brake,you can even use the booster/master with a little modification.
steelhorse is offline   Reply With Quote
Old 08-22-2008, 09:16 AM   #9
Shyguy
Junior Member
Shyguy's Avatar
These trucks are designed to be used to tow and haul stuff.
Others have given great comments.
You need to make sure that about 10% of the combined weight of the boat and trailer are on the tounge or you will have a lot of problems with swaying, especially at speeds over about 50 mph.
Also air shocks in the back would be a good idea.
Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 08-22-2008, 09:20 AM   #10
67ChevyRedneck
67ChevyRedneck's Avatar
Boats and trailers existed in 1967-1972 and they didn't haul themselves...
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 08-22-2008, 09:24 AM   #11
woodridge
woodridge's Avatar
Now that was profound.
SEMA Network- Protect our Hobby!
71 C30 in pieces, starting to come together.
Click here for A Place For Tennessee Truck Enthusiest To Meet
woodridge is offline   Reply With Quote
Old 08-22-2008, 09:48 AM   #12
69long"n"low
69long"n"low's Avatar
Ill say. i work on boats all day i had to use my 69 to tow a 4400 pound boat on the bumper with 4 wheel drums it towed it just fine. Big thing take it slow and take the corners wide
- Josh
Im not white trash, I'm one step above that..... more like white clutter
69long"n"low is offline   Reply With Quote
Old 08-22-2008, 10:11 AM   #13
Longhorn321
Size Matters
Longhorn321's Avatar
Since you are so un-attached to this truck, I say sell it (cheap) and quickly (to me). Seriously tho, if you are talking about the truck in your avatar, I would hook it up and drag it down the road and see what it's like and then make the needed adjustments and then head for the lake. BTW if the truck in your avatar is the one you are referring to in your sig, I don't think it's ugly at all. Is it "green" or yellow?
"Reading the owners manual is only for quitters." Jason Harper, Bloomberg News.
...WOOOO HOOOO!!!!
Longhorn321 is offline   Reply With Quote
Old 08-22-2008, 10:16 AM   #14
Longhorn321
Size Matters
Wanna trade for a '69 Longhorn? I don't think the Longhorn would know that boat was back there!
...WOOOO HOOOO!!!!
Old 08-22-2008, 10:29 AM   #15
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
I'm not particularly proud of this, and I deffinetly don't recommend anyone else do it, but I hauled 5600lbs of scrap metal on a 2000lb trailer with my c10. Power discs, 350/350, 307 gears.
It pulled and stopped good...not great, but good. (I did not know the load was that heavy till I got to the scrap yard!) I stress, DO NOT pull that much.
More sane wieghts it'll pull like no body's business.
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 08-22-2008, 12:35 PM   #16
mrein3
mrein3's Avatar
When I first got my truck it was a 3-on-the tree manual. I used it all the time to pull my boat. Since then I've changed the manual out and put in a th350 automatic. It isn't impossible with the manual but the auto sure is a lot easier at the ramp.
Don't worry about the pulling. It is the stopping you need to worry about. My bass boat is 2400 pounds without any gas in the tank or tackle in the bins. I'm guessing that with 40 gallons of gas and the trailer I'm rolling along right at 3000 pounds. Long story short you should be ok with manual disc brakes and manual tranny. If you swap in a power booster it will be much easier for you to stop it.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 08-22-2008, 02:32 PM   #17
cdowns
cdowns's Avatar
i towed an 19'bostonwhaler all the time and even with it loaded up with a bunch of extra stuff my 71had no problem with a 1500mile tow with no brakes on the trailer
Old 08-22-2008, 04:17 PM   #18
beeftip
beeftip's Avatar
Thanks for all of the encouraging replies. I'm think I'm going to add a booster and take the advice of practicing before hitting any major thoroughfares.
It seems to me from your replies that my ability to drive intelligently is going to be the biggest factor in my success towing a boat with my truck. Good to see that common sense can still prevail. Now if I could just find me some, I'll be okay.
1970 Chevy CST-10
Manual Drum Brakes
Weak Wiper Motor
It's for sale!
