Old 08-21-2008, 07:22 PM   #1
ca180
tryin to get laid
Can somone explain this bag setup?
Can anyone tell me how this works? Or is it not complete? I didn't want to crap in that thread so I thought I'd start another...
ca180 is offline   Reply With Quote
Old 08-21-2008, 07:32 PM   #2
Albatrossian
Georgia Boy
Albatrossian's Avatar
Re: Can somone explain this bag setup?
Looks like the red tank there is for air and the blue things under the axle are the airbags that lower or raise the rear of the truck.
Albatrossian is offline   Reply With Quote
Old 08-21-2008, 07:36 PM   #3
lyrikz
PITbut
lyrikz's Avatar
Its not done yet. Those blue things look like rags under the axle. the bags are next to it with no top mounting plate.... Thats my guess...
lyrikz is offline   Reply With Quote
Old 08-21-2008, 07:38 PM   #4
dubdeuce80
dubdeuce80's Avatar
yes. those rags are between jack stands and the axle so not to scratch the axle.
dubdeuce80 is offline   Reply With Quote
Old 08-21-2008, 07:39 PM   #5
hotrodhomi
hotrodhomi's Avatar
pretty sure the blue things are rags that are protecting the frame from the jack stands. The air bags are black and located on the outside of the frame rails. This set up is not finished, there's no upper bag mounts.
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 08-21-2008, 07:40 PM   #6
hotrodhomi
hotrodhomi's Avatar
I guess I type slow.
'66 impala ht
Old 08-21-2008, 07:40 PM   #7
lyrikz
PITbut
lyrikz's Avatar
You copying me??? LOL
Old 08-21-2008, 07:43 PM   #8
ca180
tryin to get laid
Sorry, I didn't explain my question better.
I know what the tank is, I didn't see the rags so that doesn't matter, and i know there aren't top bag mounts....
What I meant was, Is he still gonna run the leaves and bags? Does that get low? I've never seen that before. Most are 3 and 4 links...
Old 08-21-2008, 07:44 PM   #9
lyrikz
PITbut
lyrikz's Avatar
ahh damn, you got us alll... I would think he is removing that, but from the looks of the paint, i think thats staying...
Old 08-21-2008, 07:51 PM   #10
dubdeuce80
dubdeuce80's Avatar
probably just helper bags...n2trux is using leafs still IIRC. not everyone uses bags to lay out, and from the looks of his notch, hes one of them.
Old 08-21-2008, 08:22 PM   #11
ca180
tryin to get laid
Apparently its called air over leaf... wonder how low it goes.
I'd like to run bags up front to get flat, maybe that in the rear for a nice drop.
Old 08-22-2008, 01:00 AM   #12
N2TRUX
Happy to be here
N2TRUX's Avatar
AOL set up that doesn't have the top bag brackets installed yet. It gets you low enough that the pumpkin is about 1" from the bottom of the bed. If you don't want to cut the bed, that's about as low as you can get.
Here's mine-
The C-notch
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-22-2008, 01:01 AM   #13
N2TRUX
Happy to be here
N2TRUX's Avatar
The set up-
Articles-
"Refining Sierra"
Old 08-22-2008, 01:03 AM   #14
N2TRUX
Happy to be here
N2TRUX's Avatar
And the results-
Articles-
"Refining Sierra"
Old 08-22-2008, 01:11 AM   #15
kevinr1970
So do the leaf springs only act as a way to keep the axle attached to the frame; they don't support the weight of the truck or provide any suspension?
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 08-22-2008, 01:12 AM   #16
CNC
CNC's Avatar
IMO that is lowering done right, Nice stance, full use of the bed, not tearing up the street or the underside of the truck. Plus I bet that one rides real nice.
CNC is offline   Reply With Quote
Old 08-22-2008, 02:26 AM   #17
xtreme80
Wishin' I had more money!
xtreme80's Avatar
The leaf springs are there instead of using a link setup. It's the cheaper way to do it money wise, but it's still a decent setup. The leaf springs are there only to keep the axle from tracking side to side, front to back, etc.
xtreme80 is offline   Reply With Quote
Old 08-22-2008, 08:30 AM   #18
wicked_sky_gazer
Living Legend
wicked_sky_gazer's Avatar
I have never seen and air over setup, or helper bag setup used like that before (to lower) everyone aroundd here uses them to increase their tow capasity and improve tow quality and seldom if ever put any kind of notch with it.
'81 c10 sw 355cid roller motor 350turbo with stage two shift kit, poor rear end gearing, not sure peg speed... speedo is mia..
project is temporarily on pause again... Thankyou wonderfull economy.. check it out
Im not to worried i have an uncaning ability to save myself from some weeeiiirrd crap
East Ok meet East Ok date
Tony
wicked_sky_gazer is offline   Reply With Quote
Old 08-22-2008, 10:22 AM   #19
JCampbell
Some of you young men need to go pick up some old Truckin' mags from back in the day. That's the O.G. way to bag a truck right there. That's how it was done before everyone and their step brother became a 'fabricator'.
Believe it or not, some pretty awesome trucks were built before F.B.I. or Suicide Doors came around. I know it's hard to believe, but it's true.
JCampbell is offline   Reply With Quote
Old 08-22-2008, 01:23 PM   #20
spr85gmc
spr85gmc's Avatar
i think thats a may be a pretty good set up though we rarely see it any more it looks good .. my question is it better to run BOL or to use 2 or 4 link??
spr85gmc is offline   Reply With Quote
Old 08-22-2008, 01:44 PM   #21
xtreme80
xtreme80's Avatar
"better" is all a matter of personal preference. a link setup will generally give you more adjustability, and allow you to lay out completely with the right size notch.
I think the AOL setup as shown above puts a little too much stress on the leaf springs, and being that people usually remove a leaf or two or three, I think it would be prone to breaking over time.
But that's just my opinion, most will probably disagree.
Old 08-22-2008, 01:53 PM   #22
ca180
tryin to get laid
Hey, N2TRUX... thats the firestone ride rite isn't it? Which one did you purchase? Do you have a model number? I wanted to see if I could find someone that carries it locally.
Old 08-22-2008, 03:18 PM   #23
CNC
CNC's Avatar
Off topic, What year T-Bird is that 60 what?
Old 08-22-2008, 03:46 PM   #24
impalamark
impalamark's Avatar
It's a fairlane
MArk
impalamark is offline   Reply With Quote
Old 08-22-2008, 04:32 PM   #25
CNC
CNC's Avatar
Oops, From the angle it is at it looks rear close to my Pop's 64 T-bird.
