Old 08-21-2008, 09:08 PM   #1
Raymo
Wheel spacers from 6 to 5 lug???
I've got a 68 longbed that someone installed 5 lug disc brakes on the front and left the rear alone-6 lug pattern. Don't want to spend the bucks now for new axles, I thought of spacers. What do you think? Any experience with them? I'd like to leave the 5 in the front as is and change the 6 in rear to a 5. Hate having 2 different spare tires!!! Where can you buy them?
Raymo
Raymo is offline   Reply With Quote
Old 08-21-2008, 11:15 PM   #2
Husker
Husker's Avatar
Re: Wheel spacers from 6 to 5 lug???
I am going to add a set to the rear of My 4x4 to even the rear up with the front and was thinking of these, Made in The USA
Ron
http://www.weirdharoldscoolparts.com/new%20page0.htm
http://www.wheeladapter.com:80/
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is offline   Reply With Quote
Old 08-25-2008, 11:07 PM   #3
Raymo
Thanks Ron. I tried one of these guys and he said "he couldn't help me". I'd like to use spacers as opposed to changing the rear axles cause of the expense, and I like having the 5 hole discs. Seems you can buy wheels w/ 5 lug pattern easier than 6. Any ideas?
Raymo
Old 08-25-2008, 11:24 PM   #4
Husker
Husker's Avatar
Raymo, Which one told you they could not help ya? I have emailed one and have to call him back but have not called Wired Harolds yet.
You can always go this route, they have 1", 1.5" and 2" with 7/16" lugs
Ron
http://cgi.ebay.com/ebaymotors/Wheel...spagenameZWDVW
Member #111
70 4x4 Project
76 Jeep CJ-5
Thomas Jefferson
Old 08-25-2008, 11:30 PM   #5
Primered_69
Primered_69's Avatar
It might be chaper to get some 6 lug rotors from one of the board vendors.
1969 Chevy LWB - with shaved handles; 3 1/2 front/ 5 1/2 rear drop; (waiting to be put back together)
Primered_69 is offline   Reply With Quote
Old 08-25-2008, 11:34 PM   #6
Raymo
Ron,
It was wheel adapter.com
Raymo
Old 08-25-2008, 11:41 PM   #7
streetstar
streetstar's Avatar
I wouldnt do it --- i would rather carry 2 spares for no longer than it will take you to get either some axles and drums for the back, or new rotors for the front
Try to put back $100 a month and you will be able to fix it the right way in 3 months
Are you retired too?
Nonsense! I'm in my prime
streetstar is offline   Reply With Quote
Old 08-26-2008, 12:42 AM   #8
PHAT TONY
PHAT TONY's Avatar
I'll soon be in the same boat, thought about having rear axles drilled for 5-lug pattern 'cause 5 bolt axles are too long for my '67(putting 5 bolt discs on front)
PHAT TONY is offline   Reply With Quote
Old 08-26-2008, 11:33 PM   #9
Husker
Husker's Avatar
If you use GOOD Quality Wheel spacers/adapters you should not have any problems if they are properly installed.
Ron
Member #111
70 4x4 Project
76 Jeep CJ-5
Thomas Jefferson
Old 08-27-2008, 01:35 AM   #10
whatnow123
whatnow123's Avatar
I don't know, but something about wheel spacers just doesn't sit well with me even though I'm sure it's perfectly safe.
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners.
Build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=219094
whatnow123 is offline   Reply With Quote
