Old 08-21-2008, 09:13 PM   #1
Razr
1969 C-notch problem
Ok so I ordered a c-notch from CPP for my 1969 gmc w/leaf springs. I wanted to install a flip kit and needed the c-notch. However the guy at the suspension shop told me I ordered the wrong c-notch. He said it is suppose to sit flush with the frame and mine doesnt. Here are some pics of my c-notch if u can see it has a curve to it is that how it suppose to be. Need help
Razr is offline   Reply With Quote
Old 08-21-2008, 09:49 PM   #2
Dadsredwagon
Dadsredwagon's Avatar
Re: 1969 C-notch problem
looks like the ones I just got for my 65?
Dadsredwagon is offline   Reply With Quote
Old 08-21-2008, 10:59 PM   #3
gringoloco
A guy with a truck
gringoloco's Avatar
That is correct. The 63-72 frames are crooked in that area- the notch is contoured to fit. The suspension guy is probably just not familiar with these trucks...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 08-21-2008, 11:01 PM   #4
Razr
Ya but my truck has a straight frame.
Old 08-21-2008, 11:07 PM   #5
gringoloco
A guy with a truck
gringoloco's Avatar
Then you either have a 4wd frame or a later model swap. All of the 2wd frames, coil or leaf, had the crooked rails- AFAIK. Maybe post up some pics and we can figure out what you're dealin' with.
-Chris
Old 08-21-2008, 11:09 PM   #6
scotts62
One day...
scotts62's Avatar
I have seen that too, were some frames are straight and some are crooked to fit the notches like the ones you have there. I orderd the same ones that you have and ended up making the frame from c notch back.
Scott
93 crew cab build
Project 62
Old 08-21-2008, 11:16 PM   #7
gringoloco
A guy with a truck
gringoloco's Avatar
I just noticed that you have a 3/4 ton, dunno if that makes a difference. I just know 1/2 ton stuff. I know the 3/4 coil trucks were 'crooked', dunno 'bout the leaf trucks...
There are bunches of places that sell bolt-in notches for straight rails. Check out ***************** for a cheap, high quality piece.
-Chris
Old 08-22-2008, 01:43 AM   #8
Razr
these are the pics of the frame
Old 08-22-2008, 08:32 AM   #9
Shane
Shane's Avatar
C notch is correct for the years in a 1/2 ton ...
Shane is offline   Reply With Quote
Old 08-22-2008, 12:42 PM   #10
Razr
ya but does it fit my truck.
Old 08-22-2008, 02:33 PM   #11
PBFAB.COM
PBFAB.COM's Avatar
Nope. Your rails are straight. The contoured notch in the above pictures will not fit your frame.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
