Old 08-22-2008, 10:35 AM   #1
Ford Assassin
Ford Assassin's Avatar
Question Will 20x9's Work Up Front?
Hey guys, I've been doing some rim shopping and I found a few that I like, but they are 20x9's. I was planning on just running them on all 4 corners, but wondered if I could get away with them in the first place on the front of my '69 C10. I can get them in any backspacing I want, so that's not an issue and I was thinking about 255/45/20 for tires up front (295/45/20's in back).
Thanks!!
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
Old 01-06-2009, 04:15 PM   #2
Ford Assassin
Re: Will 20x9's Work Up Front?
Anyone?
Cable
Old 01-06-2009, 05:36 PM   #3
VA72C10
VA72C10
VA72C10's Avatar
I know people run 8.5" with no problem w/ 4.5" BS. Honestly not sure but here's a free bump for you.
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 01-07-2009, 03:25 AM   #4
matthufham
shouldn't have a problem with the right backspace, however i dont have those specs. they should tuck if its lowered, and i'm sure that's why you're questioning.
matthufham is offline   Reply With Quote
Old 01-07-2009, 04:08 AM   #5
Ray Rust
Ray Rust's Avatar
can't see why not , I'm running 22x9's with 305x40's on all corners
Ray Rust is offline   Reply With Quote
Old 01-07-2009, 05:23 AM   #6
Frizzle Fry
Frizzle Fry's Avatar
My 20x8.5's have 5.25" BS. So a 20x9 would need around 5.5" BS. Maybe not quite as much if you have drums.
Frizzle Fry is offline   Reply With Quote
Old 01-07-2009, 12:42 PM   #7
Ford Assassin
Pics?
Cable
