Old 08-22-2008, 11:22 AM   #1
alvanhoose
79 c10 parts on 67 c10
anyone what mods needs to be done to put 79 c10 pwr disc brakes and pwr strg (if any) on 67 c10
alvanhoose is offline   Reply With Quote
Old 08-22-2008, 12:23 PM   #2
steelhorse
steelhorse's Avatar
Re: 79 c10 parts on 67 c10
You need to either switch to ball joints for the 79 or just bolt the 79s upper and lower control arms on your 67.For the steering the frame needs a small dip in it where the box bolts up to keep it from hitting the frame.68 and up have this already there but 67s dont.Just mark where it hits and take a torch and heat it up and "massage"it with a hammer.You could shim it with some washers but I dont like that method as much.You can also use the booster and master but the rod needs modified.
steelhorse is offline   Reply With Quote
Old 08-22-2008, 01:12 PM   #3
jorgensensc
jorgensensc's Avatar
Or you could unbolt the whole front crossmember, drill a couple of new holes, and bolt in in place of your old crossmember. I definitely agree not to shim the power steering box. You will wear out your box quickly by doing that.
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
