08-22-2008, 12:19 PM | #1 |
It followed me home?
Major rubbing with new spindles installed
I just installed 2.5" drop spindles (from Mcghaughy's) and now my rally's rub on the steering arm? I called Mcghaughy's and they told me you can run spindles and rally's.
Did I do something wrong with the install?
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
08-22-2008, 12:33 PM | #2 |
Gettinlow & Goinfast
Re: Major rubbing with new spindles installed
no you did it correctly they just didnt speak truthfully, i had the same problem.
Protouring Texas built rides- 78' K5 bodied on 22's, 5.3/ 4L60E- sold-Bdydrptk5- http://67-72chevytrucks.com/vboard/s...d.php?t=358390 71' Chevelle #Bigbootyjudy 6.0 LSx, LS9 heads, Magnuson, T56 - http://ls1tech.com/forums/conversion...e-ly6-t56.html 70' Chevelle #EvilAnnie Lsx/4L80/S475 turbo- 85' C20 crew, 5.3/6L90/S475 turbo- 68' C10 5.3/4L60/Level 2 coil overs Facebook- Protouringtexasdotcom Instagram- @Protouringtexas |
08-22-2008, 01:00 PM | #3 |
Drive it around the block a few times. It'll fix itself.
08-22-2008, 01:12 PM | #4 |
just ust the grinder or buy bigger wheels.. problem slved
08-22-2008, 01:49 PM | #5 |
Cruzzzn' Vet
I'd run a 1/4" spacer on there for now
08-22-2008, 01:52 PM | #6 |
It'd be alot cooler if you did
I've heard of this problem before, but I do have some info that might save you some trouble. I have DJM 3" spindles on the front of my truck, and I have been using 15x7 caprice ralleys to push it around the shop. The look identical (except they use a slightly "shallower" trim ring) to truck ralleys and most of all they don't rub.
here is a pic of my truck with said ralleys. They will accept a regual truck center cap - i've had them on there in the past. Last edited by smashingchuck; 08-22-2008 at 01:55 PM. |
08-22-2008, 01:59 PM | #7 | |
My buddy ordered spindles from LMC and they ended up being McGaughy and neither of us could get them to fit. The spindle shaft wasnt the correct length or diameter to fit 1" or 1.25" rotors so we had to toss them. Do you have the right rotors and bearings?
1986 C10 - LWB, 305/700r4, posi, vortec heads |
08-22-2008, 07:09 PM | #8 |
that happen to me belltech spindles, and huge rubbing, just bust out the grinder until it fits.
08-22-2008, 11:03 PM | #9 |
Looks like I get to spend a few minutes with the grinder this weekend ha ha. Thanks for the info everyone.
08-22-2008, 11:05 PM | #10 | |
08-22-2008, 11:35 PM | #11 |
X2 I wouldn't use the grinder too much, when spacers are so cheap.
Chickenhouse chopshop 81 rcsb chevy bagged LS1/4l60E(under the knife) 94 ecswb L92 headed LQ9/ 4l80E(waiting to go under the knife) 78 rcsb chevy LQ4/4L80E |
08-22-2008, 11:52 PM | #12 |
Spacers are good but I still needed to use the grinder. Also what size rims do you have? I had 15s that rubbed and locked up, so I busted out the grinder and put spacers...but I now went to 20s and I had alot more room than I did with my 15s. So if you plan on buying bigger rims you may not have to do anything.
08-23-2008, 03:39 PM | #13 | |
Frank
Born and proudly residing in a Red State ! |
08-23-2008, 07:41 PM | #14 |
One day...
Yea i had the same prob, grinder works great, but 20's work better
08-23-2008, 07:50 PM | #15 | |
I'd love to buy some new wheels/tires but my money right now is tied up in getting the blower installed and interior finished.
08-23-2008, 09:00 PM | #16 |
One day...
haha yea i hear ya, i bet it looks good!
08-25-2008, 12:41 AM | #17 |
The upper and lower balljoint nuts and the tierod ends use castle nuts with retaining pins . There should be a couple holes in the shaft to choose from . Definitely reinstall them because if the nuts arent installed with them in place , they can back off . Then the vibration can cause the nut to loosen and fall off and the balljoint or tierod end to come loose . Either of these can have devistating consequences . Install those pins so nothing bad happens .
Frank
08-25-2008, 05:59 AM | #18 |
Old Heap Driver
I had the same problem with 2 ½ inch Bell Tech spindles and 15 X 8 (4.25 back space) rally wheels. Used a grinder on the lower control arm, just a little and mine still rub on lock to lock turns. I wanted to use some ¼” spacers I have but I couldn’t find any wheel studs that were a little longer. Anyone have a source or part number for longer than stock wheel studs?
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
