08-22-2008, 12:35 PM | #1 |
suburban 2wd frame
I just havent been able to find a 69-72 1/2 ton 2wd suburban fram anywhere close by me in oregon. So is it possable to use a chevy pickup frame? Wheelbase the same? any info will help...
Thanx in advance
Lowered 2002 PT Cruiser ONLY for mileage. 1969 Stepside 4x4 ( under construction ) |
08-22-2008, 01:01 PM | #2 |
Junior Member
Re: suburban 2wd frame
I am not an expert but I believe that the only difference is at the rear. The burb frame is a little longer for the bumper to mount. You could use a truck frame but would have to make some bumper bkt extensions. Like I said I am no expert but I believe it works with the bumper being your only curve.
08-22-2008, 01:07 PM | #3 |
Other then the rear bumper bracket area, do you know if the body mounts are all in the right spot? Thanx
08-22-2008, 01:47 PM | #4 |
Some of the suburban mounts are different.
08-22-2008, 03:22 PM | #5 |
l l Agree, . I've got a nice 71 Burb frame here in Albuquerque. It's got disc brakes and a posi. R/
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
