Old 08-22-2008, 06:06 PM   #1
LuckyHenriksen
LuckyHenriksen's Avatar
Removal of Clutch pedal?
Hey I need to get rid of my clutch pedal and can't get it to come off. I have it pushed as far as it will go but the edge of it is hitting the firewall. Do I need to get the BFH and clearance the firewall or is there another way?
1968 Yenko Chevy LWB
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
LuckyHenriksen is offline   Reply With Quote
Old 08-22-2008, 06:12 PM   #2
kwmech
Re: Removal of Clutch pedal?
Once the spring is off, it should slide out of the mount
Old 08-22-2008, 06:14 PM   #3
cparman
sharp as a marble
I tried to do this the lazy way. cut off wheel, and leave the rest. After I got over being a hack, it came right out. My guess is that if you cut the pedal as hight as you can, then you will get the swing room to remove it. I just finished a 3 on the tree to 700r4 conversion. Hope this helps
cparman is offline   Reply With Quote
Old 08-22-2008, 06:16 PM   #4
jef5150
Inline 69
jef5150's Avatar
HERES A LINK WITH A PICTURE
http://67-72chevytrucks.com/vboard/s...ad.php?t=95341
Jeff
jef5150 is offline   Reply With Quote
Old 08-22-2008, 07:11 PM   #5
LuckyHenriksen
Thanks for the replys! I thought about cutting it but didn't want to start the carpet on fire. I am going to repost that pic and show you where im having problems. Thanks guys
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 08-22-2008, 07:34 PM   #6
LuckyHenriksen
Heres the same picture that I updated. Sorry its hard to read, I don't have paint on my MacBook so I had to email it to my little brother and have him do it for me then email it back.
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 08-22-2008, 08:23 PM   #7
cparman
sharp as a marble
wack the pedal as high as you can, and it will clear the fuse panel. I DID
Old 08-22-2008, 08:48 PM   #8
jef5150
Inline 69
jef5150's Avatar
i just climbed into my cab (no seats in it)
and pushed my clutch in with my hand (ate a good lunch)
and the top of the pedal (where you removed the spring from), clears that "hump" you pointed at, by an 1/2 ' .....It should come out.
jeff
Old 08-22-2008, 09:07 PM   #9
LuckyHenriksen
Hmmm I'll keep trying, Thanks guys
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 08-22-2008, 09:10 PM   #10
LuckyHenriksen
I'm going to have to take a hammer to that hump, because Ive tried everything and it still won't clear.... Or maybe I'll cut it off. What is the best way to cut it off?
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 08-22-2008, 10:26 PM   #11
Arad68
Trucks N Tranzams
Arad68's Avatar
Dude,
Dont bust up your truck, you'll regret it. If you have to remove the support or just cut the pedal with a grinder or dremel
Don
'68 Chevy LB 383 TH400/GV/373 posi
'56 Chevy 4WD SWB
'64 Chevy short stepside
'79 Trans Am 455/TH2004R/12blt/4whldisc
95 Kia (Wifes car)
2002 S-10 extended cab pickup
"God punishes small sins immediately"
Arad68 is offline   Reply With Quote
Old 08-22-2008, 10:50 PM   #12
LuckyHenriksen
Thanks for that advice, I really don't want to hit it with a hammer either. A cut off wheel would be best to cut it?
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 08-22-2008, 11:04 PM   #13
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
I have NEVER had one that would slide out and clear that hump- so I just wack the pedal off with a cutoff wheel- takes a whole minute
You can dampen an old towel to protect your carpet, and throw it away when you are done
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD
'72 K20 500 Cad/TH400/NP205 SOLD
'92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver
'72 Monte Carlo... sweet low mile toy
'11 Dodge Challenger IE 392 6spd... midlife car
jeffspower is offline   Reply With Quote
Old 08-22-2008, 11:20 PM   #14
LuckyHenriksen
Awesome thank you. I'm glad someone else has this problem
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
