Old 08-23-2008, 10:19 AM   #1
haeusser
Junk pressure switch?
I recently put airride on my 72. My compressor fills the tank, shuts off for a few minutes, then kicks back on and doesent shut off. I did the soapy water test on all my fittings, no luck. Could this just be a bad switch?
haeusser is offline   Reply With Quote
Old 08-23-2008, 12:01 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: Junk pressure switch?
put a pressure gauge on it and see if its building to much pressure.
disconnect the power after its up and see it the pressure or bags drop. It could be a bad pressure switch but I suspect a leak in something . maybe the compressor head is back feeding or a bags is leaking. Do you have a oneway valve after the compressor out line?
dwcsr is offline   Reply With Quote
Old 08-24-2008, 02:03 PM   #3
haeusser
yes there's a check valve after the compressor, before the tank.
