08-23-2008, 03:11 PM | #1 |
TBI question
Hey All,
I have a question thats probably just so painfully obvious, that i cant figure it out! On my 88 jimmy, when you rev it a bit in neutral, it pops and backfires a bit as the rpm decrease.It is also seeming to be a bit sluggish on acceleration. I just did an engine swap, and it did it with the old engine, too. I am assuming its probably the tps, or maybe even the throttle body itself. Has anybody else had this problem? Thanks |
08-23-2008, 07:33 PM | #2 | |
One day...
Re: TBI question
But that may not even be the problem but its worth checking if you have done everything else. Good luck |
08-23-2008, 08:04 PM | #3 |
Re: TBI question
did it idle high, too?
08-23-2008, 08:59 PM | #4 |
One day...
Re: TBI question
no it wouldnt even run at times but when it did it ran like it was on 3 cylinders and sputtered and back fired
08-23-2008, 10:11 PM | #5 |
Re: TBI question
sounds like a bit different problem, then
08-23-2008, 10:45 PM | #6 |
tryin to get laid
Re: TBI question
Sounds like a vacuum leak
