Old 08-23-2008, 04:16 PM   #1
57larry
Rear end swap 73 in a 84
any problems swapping the rear end from a 73 to a 84 frame ? thanks
57larry is offline   Reply With Quote
Old 08-23-2008, 06:09 PM   #2
crawdadfox
crawdadfox's Avatar
Location: New Orleans Louisiana.....a great place to visit but you wouldn't want to live here!!!
Re: Rear end swap 73 in a 84
If the truck is a half ton the 12 bolt will bolt in place of your 10 bolt.The u-joint size will not be same, but you can get the joint's with diff. size cap's so you don't have to the yoke's on your drive shaft or rearend. Just remember to measure the width of the joint and cap size on both the yoke's ( i got my last one from Napa)
crawdadfox is offline   Reply With Quote
Old 08-23-2008, 06:21 PM   #3
57larry
both trucks are 1/2 ton and I got both driveshafts. thanks for the info
Old 08-25-2008, 03:24 PM   #4
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Gchemist has done this. I think he can tell you what part number the adapter u-joint is.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 08-25-2008, 07:34 PM   #5
57larry
ok thanks
