08-23-2008, 06:07 PM | #1 |
Old Skool Club
What is this??
On the left side of my chassis, near the firewall, I have a loop attached to the frame. A good friend, who has worked on many of these trucks and scrapped a good number of them (before they were valuable) said he'd never seen one.
So, what it is and what it is used for? There are no marks to indicate anything ran beneath it or was attached to it. So.....
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
08-23-2008, 06:17 PM | #2 |
Active Member
Re: What is this??
Is there one on the other side? Maybe a tie down while being shipped??
08-23-2008, 06:20 PM | #3 |
Old Skool Club
Re: What is this??
Nope....just the one.
Good 'un, huh?
08-23-2008, 06:27 PM | #4 |
Trucks N Tranzams
Re: What is this??
It appears to be a bracket for engine torque strap. (In case the motor mount failed or was broken.)
Don '68 Chevy LB 383 TH400/GV/373 posi '56 Chevy 4WD SWB '64 Chevy short stepside '79 Trans Am 455/TH2004R/12blt/4whldisc 95 Kia (Wifes car) 2002 S-10 extended cab pickup "God punishes small sins immediately" |
08-23-2008, 06:29 PM | #5 |
Active Member
Re: What is this??
Re: torque strap.... Yeah but why only on one side.
If there were two, I'd say something to lift the frame up with in the factory. |
08-23-2008, 06:34 PM | #6 |
I have a radical idea!
Re: What is this??
The torque straps were dealer installed, so maybe they took a shortcut?
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 08-23-2008 at 06:34 PM. |
08-23-2008, 06:43 PM | #7 |
Roadtrip!
Re: What is this??
Factory engine hold downs. If the motor mount broke, that would hold it in place. Didn't need to be on both sides as the torque from the engine would only lift it one way...
I have seen most of these on 67-68 models.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
08-23-2008, 06:52 PM | #8 |
Roadtrip!
Re: What is this??
Forgot to add that there would be a cable that ran under the loop and both ends would bolt to the engine...
08-23-2008, 06:59 PM | #9 |
Re: What is this??
I've had several cars from that era that had the straps, but I've never seen them on a truck. I just went out and looked, and of the 13 I have here at home, none of them have it.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
08-23-2008, 07:51 PM | #10 |
high-Tech Red Neck
Re: What is this??
You must be out of breath. have a cold one on me.
"He used to be a pretty nice feller, now he's a welder!" |
08-23-2008, 08:38 PM | #11 |
its all about the +6 inches
Re: What is this??
recall dated may of 72
As found in the glove box of my first longhorn It specificly says 10 - 30 series trucks on the recall, and it is for the motor mounts. I have only seen one truck (was a 71 or 72 GMC in a new orleans junk yard) that had the recall retrofit straps, but it had the loop like your photo shows, and still had the cable looping around the exhaust manifold. |
08-23-2008, 11:27 PM | #12 |
Re: What is this??
My 70 HAD one of these, when i put in the 6.0, i noticed that it was not needed and it was tossed by the wayside!
70 CST, 6.0/ 4L80E in the works. *Custom harness by 68 Short Step* |
08-23-2008, 11:45 PM | #13 |
Re: What is this??
I Have a complete setup from a 70 Chevy. They were suppose to be on both sides.
Ron
Member #111 68 C-10 Daily Driver 70 4x4 Project 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
08-24-2008, 08:35 AM | #14 | |
Old Skool Club
Re: What is this??
If this is the true purpose (and what else could it be for?), then why don't we see more of them? Thanks for answering the mystery question.
08-24-2008, 08:56 AM | #15 | |
Active Member
Re: What is this??
It sure sounds like a bandaid for a potentially dangerous situation. Times have changed.... |
08-24-2008, 09:33 AM | #16 |
Re: What is this??
The Passenger side did mount to the Exhaust Manifold and the drivers side mounted to the block, If I remeber correctly.
Ron
08-24-2008, 10:22 AM | #17 |
Keepin it runnin!
Re: What is this??
What can also happen if the engine were to torque enough is the clutch linkage could possibly pop out, leaving you SOL without a clutch and the engine throttle stuck at a high RPM. My 70 Jimmy had this exact event occur when I was 16, making a left hand turn (thankfully) into an empty parking lot. I came out on the clutch just hard enough and was giving enough gas that the shifter also got messed up at the same moment. The truck had the 3 on the tree and the driver side motor mount ripped in 2 pieces. So it was hang on and Holy Pooooo!!! When it happened it made alot of noise as the fan was grinding on the shroud. Clutch linkage pieces were in the street, it was night, no flashlight, and being stuck in 1st gear! Had to start the truck in 2nd gear and use the key to slow down at stop signs, luckily it was night and zero traffic! I did finally make it home, safe. I'll never forget that event and as a result I change motor mounts every time I think theres too much play in the motor mounts. I always wondered why they didnt make a better mount, or maybe there is and I dont know about it.
Frank
1970 K-5 4X4 Blazer 1970 K-20 4X4 Long Bed "Liberty Means Responsibility, that is why most men dread it" |
08-24-2008, 10:53 AM | #18 |
Trucks N Tranzams
Re: What is this??
GM changed the mounts starting in 73 becuase of this problem.
08-24-2008, 12:05 PM | #19 | |
Engine n00b
Re: What is this??
08-24-2008, 02:54 PM | #20 |
Re: What is this??
I'll bet why not many people have seen these is that the new design motor mounts were put on ones that came in for the recall later, or if the owner was religious about taking the truck to the dealer. whenever one came in with straps, it got the new motor mounts.
68 Chevy LWB stepside (currently hauling $#!* out of my backyard) 94 CVPI R.I.P. was fun until the tranny died, and the brake line rusted thru and the dashboard lights were blinking codes at me. 93 Exploder 09 Scion XB 01 Indian Scout |
08-24-2008, 02:58 PM | #21 |
Never Ending Projects
Re: What is this??
I still have both sides on my '68. Even when the PO swapped a 350 in for the 327, he reinstalled both straps.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
08-24-2008, 03:35 PM | #22 |
Re: What is this??
i never really paid any attention to it but i have the driverside strap on a 70 gmc 2500 i have, when i got the truck the guy who i got it from told me he had to bring it in to a dealer to have that installed but he didnt tell me what it was for just that it was there
Trial and Error, its expensive but its a mistake i most likely wont make again 1971 chevy k10 custom deluxe http://67-72chevytrucks.com/vboard/s...d.php?t=341257 1968 chevy k/10 fleet http://67-72chevytrucks.com/vboard/s...d.php?t=334731 1948 desoto custom coupe fluid drive(family heirloom) |
08-24-2008, 09:25 PM | #23 |
Old Skool Club
Re: What is this??
I remember the the "concern" that existed at that time with Chevy motor mounts, but don't recall the fix...specifically. I do remember seeing some cable straps on some cars that came in to "the World's Largest Department Store" auto shop when I was working there in '76.
What I also recall was a '72 Plymouth that a customer brought in because they couldn't get the oil filter off of the 318. When I put it on the rack, it became obvious. The motor mount was broken, and the engine had turned in its mounting just enough that the oil filter, when unscrewed, came into contact with the chassis. They were right. Neither they, nor we, could remove the oil filter....until it got some new motor mounts. I didn't fix it, and I don't know if they did or not. I'm gonna guess it don't even matter now.
08-24-2008, 09:37 PM | #24 |
Re: What is this??
makes me wish I bought those Prothane mounts and not the "made in India" ones now.!
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
08-25-2008, 01:56 AM | #25 |
Long Fleet Club
Re: What is this??
http://www.performanceonline.com/sto...96&cat=0&page=
Has anyone used these? Also can you just go to your local parts store and get new mounts for these or do you have to call them back up?
Chris Meeks '69 Chevy Custom/10 Long Bed <-- Thread of the work I did before selling. Truck is now finished to the new owners design and running around. I was shown some pictures of the finished product. At least it survived the junk yard. FAQ Index by Krue Site Vendors Subscribe Here Forum Rules |
