08-24-2008, 01:44 AM | #1 |
Rear Axle 5 lug
I purchased an 84 suburban for a donor vehicle. It will work for the front axle/disk brake conversion but will not for the rear axle. I found the 84 axle is much longer than my current.
Can I not just pull my 66 rear axles and have them converted to a 5 bolt pattern so I can maintain the same rear axle? Drum brakes are drum brakes in the rear, as long as they are not leaking and adjusted properly they work just fine; so I don't mind having the 66 axle. Steve |
08-24-2008, 12:16 PM | #2 |
Re: Rear Axle 5 lug
Yes you can have the 6 lug axle filled & redrilled to 5-lug if ya like. Gotta find the machine shop capable to do it. Also there are axle swap kits out there. For the 65-66 its just a matter of swapping the original 6-lug axle shafts for new 5-lugs. CPP or Brothers carry these axles.
..............................._________ ......___________//___[[___{\ _____ ...../__(_(O)_)___/____/____/_(O)_/ 1964 C20 Long Stepside 3 Door Crew Cab - Armbruster-Stageway Conversion Y2K INDN Chief "ONE OF A KIND, NOT ONE OF THE CROWD" Aug 2010 - Front end frame cleanup & engine swap done!!! June 2011 - Rear end bagged Sept 2011 - Rebuild motor top end Sept 2012 - Parked and slowly working on it. Aug 2013 - Front end bagged - finally! Aug 2014 - Stepside swap conversion done. Finally ready to start bodywork! Have a few KEWL ideas... Here is my build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=335427 |
