Old 08-24-2008, 01:43 PM   #1
bryanw1968
bryanw1968's Avatar
Where to buy pinion seal and crush sleeve?
My pinion seal is leaking and I need to replace it. The local parts houses and GM parts houses don't have either of them. Does anyone know where I can get one online and exactly what I should be getting? The truck is a 1968 12 bolt.
Thanks,
Bryan
bryanw1968 is offline   Reply With Quote
Old 08-24-2008, 01:56 PM   #2
whatnow123
whatnow123's Avatar
Re: Where to buy pinion seal and crush sleeve?
I'm pretty sure NAPA would have this. They have the axle seals.
Why do you need a crush sleeve? You can Pop the seal by removing the yoke. Just mark where the nut was so you don't over tighten it.
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners.
Build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=219094
whatnow123 is offline   Reply With Quote
Old 08-24-2008, 02:45 PM   #3
bryanw1968
bryanw1968's Avatar
Cool I'll check NAPA.
Thanks,
Bryan
Old 08-24-2008, 04:34 PM   #4
hdflstf
hdflstf's Avatar
J&S Gear in Huntington Beach can ship you whatever you might need if you have no success locally.
hdflstf is offline   Reply With Quote
